Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
It doesn't look stupid if you get a plate that it's designed for..
Agree it looks bad with every other plate though and a bit frustrating. Id be tempted to ditch it if using a normal plate.
You could sort it out later, and get them to reimburse the costs if it states 'euro plates' in the contract. Easier to change it later and they wouldnt be ready in time anyway.
When I got my car I had the same White plates.
I ordered premium (metallic) ones and you basically pay a pro-rata rate to get the new ones. they normally take about 2 weeks to deliver and all you do is transfer the white ones with the new ones and pay the annual fee for the Euro ones.
I don't think it's chaged much in the last 2 years but if you go down to the registry and tell them the situation they should help you out.
I'm not going to say that they don't still do that (cause I'm eating dinner and can't be bothered looking it up right now)... but they've actually rejigged the entire NSW plates system as of sometime mid last year.... so I'd double check before presuming anything![]()
Current: |MY15 W205 Mercedes-Benz C250 | Polar White | AMG | COMAND | VISION |
Previous |MY10 MKVI GTI | Candy White | 5 Door | Manual | Bi-xenons | 18' Detroits | MDI | R LEDs Tail Lights|
Coreying, I have read through the thread and I cant seem to see what peoples issues are with the plate holder on the GTI? If you want your plate to fit properly why not just order a full size euro plate (im from Victoria)? Or are there issues with the full size euro plates fitting on the plate holder too?
MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
In NSW, there is only a single Euro plate style which fits. It costs $400. The other 5 europlate styles (including the black euro plates) are only small and only take up about 1/4 of the area. There are also ~51 other NSW plate styles which do not fit.
In other parts of the country, there either is no Euro, or there are expensive annual fees (I think SA is like $150 per year... so that's $1500 over 10 years, just for a plate that fits!).
In addition, the plate must be bent to meet the substantial curve of the holder. If you wanted to put a cover on it, the cover needs to be custom made to comform to that curve (like the Lakin ones), or if you just buy an off-the-shelf traditional plastic cover which can't be bent, the plates sit approximately 1cm out from the plate holder on the left and right edge and make things look even more ridiculous.
Basically, it's just a PITA. Victoria are a lucky bunch, because they have the choice of plate size for all of their Euro options, and they're not that expensive. Then again, even if I had the option of large black euro plates, I'd still prefer the smaller size.
It is my believe that the MK6 GTI, GTD and R, should not come with the plate holder fitted, and that the dealer could fit them if the customer wanted it fitted.
I'm not sure what the situation was for the MKV, some had them, some didn't, so maybe that's what they did with the MKV. Whatever the case, they're a lot nicer without them for the majority of Australian number plate installations![]()
Thanks for that, well I have just requested the my dealer fit full size white Euro plates to my GTI that is arriving. As I said im in Victoria. So looking at the Vicroads website there are 2 styles of Euro Plates in Vic.
- Full Size
- Slim Line
Full Size seems to be the correct size to fill the plate holder. Heres hoping it works! I will post pics of my plates once I get my car!
It doesn't have to be bent that much, and mine is on there with ds tape (three vertical strips). I wouldn't use a plate protector if you're using the euro plate mount that is already on the car as it looks good like the pic i posted earlier, nice and flush.
Personally i dont like slim line europlates but if i had personalised plates a slim line would be good mounted directly on the bumper, but then you got the problem of seeing the holes where the holder was attached. You could always get the bumper re-done at a body shop.
