Page 70 of 72 FirstFirst ... 20606869707172 LastLast
Results 691 to 700 of 711
Thread: Best number plate / plate holder style
  1. #691
    You'll be able to mount the Lakin bracket straight to the existing OEM holder, Philip has seen and done it all on these cars so if you're unsure then he will be happy to talk it through.
  2. #692
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by TeamCrash View Post
    Have contacted larkin as I am trying to mount my QLD 2x2 personalised plates without drilling into them....
    Does one need to take of the OEM euro plate holder with Larkin plate holders?
    It depends on the type of holder that you ordered. Certainly my front plate holder (on my Golf R) was designed specifically to have the OEM holder removed as it looks much cleaner and flush to the car. It mounts directly in the holes that the OEM holder used.
    But as has been suggested, if you're not sure, just give Philip a call as he's extremely knowledgeable
  3. #693
    Feb 2010
    South Perth, WA
    I removed my OEM holder and plugged the holes with additional plastic clips that Philip provided which I painted. Not a fan of the big OEM plate holder. Best number plate / plate holder style-img_2093a_zpsm0oo6mvz-jpg
    WLF127
  4. #694
    I had Euros on my mind due to the old posts sitting on top - agreed, if you're not doing full sized Euro then removing the holder and going the clean finish with the plugs works a treat.
    I wish we could get the clean white on black here in SA. Maybe in a couple of decades they'll wake up..
  5. #695
    Mar 2016
    I have an idea for those holes after seeing a photo on Lakin' website. How about small white waterproof vinyl stickers, like dots, that can go over the holes ??? cheap, and 100% unnoticeable! and FLAT! unlike the ugly rounded plugs.
    if you have a white car, like me or a black car it would be perfect, those with coloured cars might have to get custom ones made up.
    Thoughts?
  6. #696
    Mar 2016
    Sticky Dots : LAKIN Custom Plate Brackets, Add some CLASS to your car
    Im not sure how strong these ones are, or if they are vinyl or long lasting. but you get the picture.
  7. #697
    Feb 2016
    Maybe laser cut acrylic that sits flush inside the hole. On the other side of the bumper you could glue the overlap. The look of it finished would look like a fake parking sensor
  8. #698
    Mar 2016
    Quote Originally Posted by mickypaps View Post
    I pick up my white golf next week, I'm going to give this a go.
    Going to find a white glossy surf sticker laying around and cut a 1cm diameter circle. If stickers stay on my surfboards through all the sun and saltwater, theres no reason why it shouldn't work on a bumper bar
    and won't be needing those ugly ugly hole plugs!
  9. #699
    Feb 2016
    How big are the holes once the bracket is removed?
  10. #700
    Around 10-12mm from memory
