Question - if you want personalise EURO plates you need to get the Premium EURO ICON plates.
However the front and back plates are different sizes. The back plate is the longer plate and one I would like to put on the front of my GTI as it fills the plate holder perfectly on the GTI as most are aware.
Are you allowed by law in NSW to swap the fonrt and rear so the larger plate is at the front???
If you used any other style the back plate may be 372mm long anyhow, so is there a requirement for the EURO???
Thanks
JP
OK - sorry - found an answer - kind of!
You cannot use the smaller plate on the back in NSW... I have however sent an equiry to RTA NSW to ask if you can get two plates at 110x520 (or two rear plates in a set) so you can put the 520 long plate front and back....
This is for the Premium EURO ICON plates only, which can be personalised - otherwise it will the the standard EURO's for me!!!!!
Will post up answer when I get a response...
BTW - DreamensioN - what you have done with yours is exactly what I want to do - the QLD personalised EUROs come in the same size front and back at 520mm, perfect!!! you guys are lucky, we don't have this option in NSW... not sure about the prices though, well over $500..... looks sweet though...
JP
Reason: Add info
2011 5DR GOLF GTI DSG 6 CANDY WHITE - LEATHER, SUNROOF, 18" DETROITS, MDI, BT
