Maybe the cow is still alive and trying to get out?
2011 Volkswagen Golf R | Black 19" |
2007 HSV VE Clubsport R8 (sold)
2005 Subaru Impreza WRX MY06 (sold)
I had a number of rattles in my R coming from the door trims/pillars etc. Nothing around the seats or centre console. These got mostly sorted out after leaving the car with the dealer.
I found more right foot or audio hides it![]()
Reading other threads, it seems the door seals squeaks and rattles are a common problem... Might require a trip to the stealership.
Isn't there some some sort of a product/lubricant that can be applied to the seals to fix/reduce these squeaks?
Yeah the dealer should do it. I had quite a few squeaks reversing out of my driveway before but after the rattle fixes and whatever else they did, haven't noticed it as much.
If it is the door seals, the reason it's occuring is because of the car wash, polish, or wax being used has got into the door jams and onto the seals. It's a common "issue" with VAG cars.
It can be resolved with Gumme Pfledge, as per the http://www.vwwatercooled.org.au/f112...ing-41289.html thread which I linked to in post #3
Also, if this started after you took delivery of the car, you should look at the wash products and process you use. Even if you've had no issues with previous cars.
So I did a little test. Pressed on the door frame and low and behold, the Sonofa@&$); started squeaking.
I cleaned the seals using isopropyl alcohol, cleaned the door frame, cleaned the felt seal
While it was wet it was ok.. Now that's it's dry it's same *****.
Merged the thread know we know it is this same thing.
Answers are here, but see my last post if you don't want to read it all...
