Page 19 of 25 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 241
Thread: B Pillar clicking / ticking & door rubber / seal creaking / squeaking
  1. #181
    Nov 2009
    Maybe the cow is still alive and trying to get out?
  2. #182
    Quote Originally Posted by dave_r View Post
    I've looked in the center console, no sign of it...
    Ok... I guess the question that I should really ask from R drivers:
    "When going over (slightly) bumpy roads or hit an uneven surface, is the cabin noise free or you hear door/centre console/dash rattles?"
    2011 Volkswagen Golf R | Black 19" |
    2007 HSV VE Clubsport R8 (sold)
    2005 Subaru Impreza WRX MY06 (sold)
  3. #183
    Nov 2009
    I had a number of rattles in my R coming from the door trims/pillars etc. Nothing around the seats or centre console. These got mostly sorted out after leaving the car with the dealer.
    I found more right foot or audio hides it
  4. #184
    Reading other threads, it seems the door seals squeaks and rattles are a common problem... Might require a trip to the stealership.
    Isn't there some some sort of a product/lubricant that can be applied to the seals to fix/reduce these squeaks?
  5. #185
    Nov 2009
    Yeah the dealer should do it. I had quite a few squeaks reversing out of my driveway before but after the rattle fixes and whatever else they did, haven't noticed it as much.
  6. #186
    Feb 2009
    Sydney, Australia
    If it is the door seals, the reason it's occuring is because of the car wash, polish, or wax being used has got into the door jams and onto the seals. It's a common "issue" with VAG cars.
    It can be resolved with Gumme Pfledge, as per the http://www.vwwatercooled.org.au/f112...ing-41289.html thread which I linked to in post #3
    Also, if this started after you took delivery of the car, you should look at the wash products and process you use. Even if you've had no issues with previous cars.
  7. #187
    Quote Originally Posted by Corey_R View Post
    Bought all new products when I got the car. Using the MINT car wash and Nanolex'd my car back in February.
    Are you saying the Nanolex coated the seals and that's what causing the squeaks?
  8. #188
    So I did a little test. Pressed on the door frame and low and behold, the Sonofa@&$); started squeaking.
    I cleaned the seals using isopropyl alcohol, cleaned the door frame, cleaned the felt seal
    While it was wet it was ok.. Now that's it's dry it's same *****.
  9. #189
    Feb 2009
    Sydney, Australia
    Merged the thread know we know it is this same thing.
    Answers are here, but see my last post if you don't want to read it all...
  10. #190
    Thanks Corey, I was reading this thread today and it's how I got the idea to try pushing on the door frames to replicate the noise.
    I'll give that Pflege a go and if it doesn't work I'm going back to VW to see what they say...
