Page 24 of 25 FirstFirst ... 1422232425 LastLast
Results 231 to 240 of 241
Thread: B Pillar clicking / ticking & door rubber / seal creaking / squeaking
  1. #231
    Jul 2012
    Lota, Queensland
    Just had Austral fix a similar issue with an intermittent noise today. They diagnosed it as the fuel line and protective sheath running in a channel from the engine bay down past drivers seat. They have injected a foam filler in the cavity to stop the noise. Will see how it goes.
  2. #232
    May 2011
    mosman nsw
    Thanks, I look forward to your update.
  3. #233
    Jan 2010
    Lubricant to cure door creaking.
    Does anyone know what lubricant and where you apple to cure the creaking? I've taken this to vw and the lubricant lasted about 1year, the noise is back. Apparently, it's a known defect .
  4. #234
    Dec 2008
    Sydney/Canberra
    Loosen the latch mechanism, and spray silicone lube between the latch and the door where their surfaces touch. Then re-tighten the latch firmly.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #235
    Jan 2010
    How do I loosen the latch mechanism? Which one is it?
  6. #236
    Oct 2006
    Quote Originally Posted by alphabeatsco View Post
    1Z Einszett Gummi Pfledge
    (Rubber Care Stick) - this was made specifically for euro cars and the door rubbers.
  7. #237
    Mar 2007
    Country NSW/Southern Tablelands
    Rubber door seal creak
    Need some help. The rubber door seals on my doors are very creaky. Most noticeable when driving over rougher surfaces or slowly over very uneven. Have had them replaced before under VW Warranty but new extended warranty doesn’t cover them. So I have tried all sorts of lubricants to stop the creaking. Used an expensive preservative/lubricating oil, silicone spray even Vaseline. Not effect, although the Vaseline now seems to have made the door a bit sticky. The oil and silicone were absorbed by the runner in minutes.
    Anyone else had this issue and been able to solve, without replacing them?
    Many thanks.
    Man In Black (MIB)
    2007 V6 4Motion Passat, Black, Leather, DSG, 18" Wheels, Bi-xenons
    2010 Mk 6 Golf R, 5-dr, Rising Blue, DSG, leather, ACC, RVC
  8. #238
    Sep 2007
    Perth
    Quote Originally Posted by Man In Black (MIB) View Post
    Many thanks.
    Google "Einszett Gummi Pflege" - I have used it as a regular treatment - easy to apply like a shoe polish applicator.
    2001 Bora 4Motion from new, upgraded Haldex controller, Bilsteins, Milltek
    2014 Golf 90TSi, Comfortline, manual
  9. #239
    Oct 2014
    Melbourne, VIC
    The only thing that will work in my experience is Gummni Pfledge, carcareproducts sell it. You're probably going to need to get the oily stuff off as well - use a general purpose cleaner/detergent. This is what the dealers use anyway (even if it is rebranded and charged at 4x the cost.....BMW....cough....)
  10. #240
    Dec 2008
    Sydney/Canberra
    Also lubricate the latch mechanisms.
    The door seals are only a small part of the problem.
    '01 Beetle 2.0
