Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 83
Thread: Automatic Wipers...
  1. #71
    Mindarie, Perth (WA)
    The wiper will return to a different position each time. It is designed this way so that the life of the blade is extended etc etc.
    Maverick did write something up about this sometime ago...and it is a great feature on the VWs. Maybe there is something in the manual, or even if you do a search on this site for +Maverick +wiper
  2. #72
    May 2010
    Sydney,NSW
    Thanks FJ Steve.
    I'll look at the manual again. I searched on this site and I do not manage to find the thread you mentioned. I'll keep searching.
    One thing I would like to mention is sometimes when it does not complete moving down, it stays there for a few seconds and may move down completely and moves up again. Does this relate to the feature as well?
    Golf MK6 GTI - Deep Black - DSG - 18" Detroits
  3. #73
    yep...pretty sure that is what you are seeing.
  4. #74
    May 2010
    Sydney,NSW
    Thanks again
  5. #75
    a post from Maverick (albeit on another forum...but you will get the idea)
    Every second time you turn the car off the car moves the arms up a little so the blade is bent in the opposite direction so that the blade wears out evenly on each side. A normal car leaves the blade in the one position all the time and the blade deforms over time and has to be replaced a lot earlier.
  6. #76
    Melbourne's East side
    Quote Originally Posted by manyoo View Post
    I'm not sure if I'm having a problem on the passenger side wiper which quite annoys me.
    When the auto wiper option is enabled, SOMETIMES the wiper does not move down completely before it moves up again. As the auto option is enabled and when the sensor does not detect any rain, it just stayed there and until I manually wipe the screen. Then it will come down completely and I'll not see the wiper from my driver seat position. The problem seems to be never happen when I manually wipe the screen.
    I think it may be the dirt on the wiper or on the screen causing the issue. Does anyone see similar problem?
    Thanks for any feedback.
    Hi Manyoo,
    I also noticed the same thing, only happens when its in the rain sensor mode.
    Most times it will sit a bit above its normal resting spot (almost like its deciding whether it needs to go another sweep or not)
    then if it doesnt do another sweep most times it will then drop back down to the resting position after approx 1 second....but not always.
    I had the car over at the service dept to replace broken interior trim and asked about this.
    The service manager made enquiries and apparently this is "normal". It may go back to the normal resting spot 19 times out of 20,
    but on the 20th time it may sit up a littler higher to prevent baldes wearing out too soon (thats what they have told me).
    Sometimes mine will stay up a little from the full resting place till I use it next, and like you I notice it from the drivers seat then too, but
    if it goes right back down I dont see it either.
    Didnt see anything in the owners manual on this and car had to go to VW anyway so was easier to ask service dept
    Hope this helps
    Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
    Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
  7. #77
    May 2010
    Sydney,NSW
    Hi GTI mk6,
    Thanks for your feedback. Your description is much better than mine. This is exactly what I experienced.
    I can see your explanation can be part of the feature FJ Steve mentioned. So I don't need to worried about it as this is normal
  8. #78
    Hi GTI mk6,
    No worries Manyoo.
    Oh I didnt even see the other responses as I opened this thread from my email, then just signed in and responded.
    I now see you already had the answers...hehe,
  9. #79
    Camberwell, Vic
    For what it is worth, and at the risk of sounding like I have some knowledge, I was always under the impression there is a distinct difference between the Auto lights and the Wipers - the latter not actually being Auto but using the rain sensor.
    Auto lights will come on when it gets dark, so you don't have to turn the switch. Simple.
    However, the first stage of the wiper is not so much an Auto mode as one which either uses the top switch to change the frequency OR the top switch to change the sensitivity of the rain sensing wiper mode. So, to my mind this wiper arm is ALWAYS off unless it starts to rain.
    Then if it does, I put it to the first position and adjust the rain sensor sensitivity so it only sweeps when there is x amount of water on the screen. Thus if it changes intensity, the wipers keep up. If I had a manual (non-rain sensor car) then it would sweep with the same frequency every time regardless of the amount of rain.
    Thus the rain sensor was not intended to be an automatic position, but one that changed the frequency of the wiper sweeps depending on the amount of rain. Thus if it was not raining, the wiper arm should be turned off.
    Thus in my book it would always be better to have the wipers off until needed to avoid any issues, and not consider them an 'Auto' position...
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
  10. #80
    Feb 2009
    Sydney, Australia
    ... or you can just adjust what you're cleaning your windscreen with and leave it in Auto for the wipers like I did for the entire ownership of my MKV GTI...
