Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 83
Thread: Automatic Wipers...
  1. #51
    Jan 2010
    Brisbane - QLD
    Quote Originally Posted by GTI-mk6 View Post
    I was told by the dealership that if you have the wipers on auto/rain sensor mode, "everytime
    you engage reverse gear", the rear wiper engages (think just one sweep), even if the window is completely dry?
    Cant test this out right now as my car is currently over at dealership for the next week.
    Personally I dont like this idea, particularly having it sweep a dry window, so would then need to
    keep wipers in the "off" position to prevent this happening.
    Can anyone confirm this?
    Must remember to try this once i get my car back
    Because I was bored, I just tried this on my MK6 TSi.
    1/ Turn on ignition
    2/Turn on auto wipe function - result - front wipers do a sweep
    3/Put DSG in Reverse - result - rear wiper does a sweep
    The car has been in the garage for 2 days so definitely no water anywhere.
    I personally leave the auto wipers OFF, as the erratic behavior annoys me. I prefer to hit the single sweep when its needed rather than scraping the blades on dry glass
    Regards,
    Brian
    Current drive:2016 Golf GTI 40 Years in Pure White
  2. #52
    Melbourne's East side
    Quote Originally Posted by Brian View Post
    1/ Turn on ignition
    Regards,
    Brian
    Hey Brian,
    thanks for confirming what they said, yep I am with you on this.....what a dumb idea having the rear wiper automatically
    come on everytime you hit reverse (if keeping the wiper stick in the rain sensor position)
    On my last car, I pretty much always kept it in this position and that was a hatch also, so it had a rear wiper that didnt activate
    unless I wanted it to.
    Think I will just manually hit the single sweep in intermittent rain, otherwise I will forget to turn the wipers off when arriving home
    and it will irk me next morning when engaging reverse, then having wiper sweep a dry window after car is garaged overnight.
    What were they thinking?
  3. #53
    Mindarie, Perth (WA)
    Trade it in on a MKV.
    Seriously...I would be going back to the dealership and getting this "issue" sorted. I have driven a MKVI GTI for numerous days...and NEVER had that problem. Yes..the wipers were set to "Auto"
  4. #54
    Jun 2009
    I would say check if the winscreen is clean on the sensor area. There were a few phantom wipes for me too..however, issue resolved when the sensor area is clean. Pull down for a quick 3 wipes, OFF, Auto(in auto play around with the sensitivity, little tricky at first but you will find the correct settings). And if it comes on too late from a few spray, then either flick it to quick wipe. Although, it is on auto, its not perfect every time, hey this keep us active too.
    Second on the DRL, it comes standard on the golf IV. I do wish they have an dash indicator to let you know when the Low beam is on. I guess just look for the purple radio light for now will do .
    GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
    GOLF VI 118TSi DSG Silver Leaf
    GOLF VII 110TSi DSG White
    GOLF VII GTI pp : on negotiation
  5. #55
    Perth WA
    We've had/have a Passat, 2 Mk V Golfs and a Mk VI Golf... all of them equipped with auto wipers, always set to auto. None of them (Mk VI included) wipe the rear window when reverse is engaged unless there is water on the front windscreen which has triggered the front wipers. None of our cars have had any issues and the wipers have worked as you'd expect, yes there have been phantom wipes but usually only if the windscreen is minging.
    I suggest you pay your dealer a visit if your car wipes every time reverse is selected.
    The other thing is if the car has been parked in the rain but it isn't actually raining when you start the car the rain sensor doesn't seem to detect the water sitting on the screen, I don't know for sure but I assume each time you start the car the sensor 'resets' and because it works off light refracting it doesn't detect the sitting water until it moves around on the sensor. I just flick the sensitivity switch up a notch and back down and it wipes and is back to normal
    Quote Originally Posted by sillygogo View Post
    Not exactly the most convenient spot but the colour of the "AUTO" on the headlight switch changes colour. From memory it's green when the DRLs are on/low beam off and changes to red when the low beam is on... it might be the other way around. North Americans have a "DRL" light in the instrument cluster, don't know why we don't get it.
    | Tiguan 125TSI DSG |
  6. #56
    Quote Originally Posted by mtj007 View Post
    Okay, once I get my car back, I will test it out.
    No, actually better still I will test it BEFORE leaving dealership (good thinking 99) just in case.
    So will make sure windscreen is dry and clean first.
    Wondering why the salesman said this to me then, maybe I miss -understood what he meant?
    I did have the setting on the least sensitive and do understand that phantom things can trigger the front wipers
    and maybe the rear one only does a sweep if the front one activated first then.......sure hope this is the case
    Thanks for your input everyone
    Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
    Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
  7. #57
    Jun 2009
    Sweet..will try it out..however, i think on mine, the lights remain the same.
  8. #58
    Jan 2008
    RTFM and you will get the same answer others have said above. The rear wiper will only operate automatically if you have the wipers on auto AND rain is detected AND you select reverse gear.
  9. #59
    Jun 2009
    Quote Originally Posted by Maverick View Post
    Thats great..i was wondering about that.why the wiper was auto on the rear when reversing and not when going forward. thats good design.
  10. #60
    What does RTFM mean please? Nothing nasty is it?
    As I said, I will try it out myself BEFORE leaving the dealership, (also just in case it is faulty).
