Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 83
Thread: Automatic Wipers...
    May 2007
    If you refer to your owners manual it will give you an explanation!
    It does this when you turn the ignition off, to help preserve the blade / rubber it moves / settles in different positions...
    Sep 2009
    Bundaberg, Qld
    Well I'll be a dead chook!... Thanks for the info. Put away superglue... read owner's manual more thoroughly!
    2009 Golf MkVI 118 TSI
    United Grey - 7sp DSG, Sports Pack, Sat Nav, Blutooth, Towbar, Park Assist
    2005 350Z Track Coupe
    Ultra Yellow - Lots of mods
    Sep 2009
    Bundaberg, Qld
    I do believe you (as it does make perfect sense) but I could not find this anywhere in the owner's manual. I read the windscreen wiper section a couple of times and could only see the bit about the "service position" which of course is a different thing.
    Nov 2008
    Sydney, Macquarie Park
    smthing to do with aerodynamics as well i think...mk5s got the same
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Apr 2009
    Don't know if its related but when I use my washers on my 05 Caddy it wipes 3 times and then waits for 20 seconds or so and then wipes once more. In between the two wiping actions the N/S wiper sits higher on the screen and then returns to the proper rest position once the last wipe is finished.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
    Canberra
    No, that's a different function again. IIRC its called "tear drop wipe" or somesuch, and it is designed to clear up those last few drops remaining from the washers.
    Apr 2009
    Is it so that a parking cop can slip a ticket under that wiper without causing damage to the bonnet?
    Feb 2009
    Melbourne, Victoria
    As everyone has said ... It does it little movement thing every time you switch it off to preserve the wiper blades.
    However - when the car's switched on and in motion, I've noticed that if you have the wipers switched to OFF then they'll sit higher on the windscreen, being visible (until you're at freeway speeds) than if you have them switched to AUTO. In the AUTO position they'll always tuck themselves away out of view when not in use.
    Jan 2009
    Please Enter Location
    Thumbs up
    Quote Originally Posted by gregozedobe View Post
    Yeah, we've had that on our old 10yo SAAB. It's very useful.
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by SLA14h View Post
    I had a Skyline new in 1986. It had a little ramp that lifted the wipers off the screen when parked. never got a ticket......
