Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Automatic Wipers...
    Jun 2009
    Automatic wipers now manual?
    Anyone know about this?
    Usually my automatic wipers work whenever there's rain but today they didn't. I had to manually control them (I almost forgot where and what to do!).
    At first when the rain was moderate I put the wipers on intermediate. Occasionally the wipers would go continuous and then resume intermediate.
    Any ideas please?
    Jun 2006
    Sunshine Coast
    Some times they just need a reminder that they are automatic, the IR sensor may be a little dirty or have road grime over it so that when the rain is light it doesn't pick it up. Try adjusting the sensitivity switch when it does start to rain and then adjust it back to a lower setting. Another solution is to turn the wipers off completely and then reset to automatic to see if they start working again.
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
    Jan 2008
    Sunshine Coast
    If the wipers are switching themselves between full and intermediate as you describe, it sounds to me like that position on the stalk IS automatic. Perhaps it had been knocked down into off, hence no auto start, and what you thought was the next click up, intermediate, was in fact auto???
    Perth
    I've experienced the same however turning them off & adjusting the sensitivity normally fixes it. I've also been told to not use glass cleaner where the sensor is as they can leave behind a thin film which diffuses the sensor's reading.
    MY08 Blue Graphite GT TSI DSG
    Jun 2009
    Thanks guys.
    They seem to be working again now.
    How does one adjust the sensitivity?
    brisbane qld
    Quote Originally Posted by Stealthy View Post
    Thanks guys.
    The information is clearly explained in your car user Guide.
    Feb 2009
    Melbourne, VIC
    Thanks guys.
    I get the same problem too sometimes.
    To adjust, it's on page 70 of booklet 3.1.
    Basically, the positions from Top to Bottom are:
    - Fast
    - Slow
    - Interval (the rain sensor is part of this)
    - Off
    - Brief
    To control the sensitivity of the rain sensor. You move the stalk/lever to the Interval position then use the interval pause control to adjust the sensitivity. My manual is screwed though. It says "Switch to the right - high sensitivity. Switch to the right - low sensitivity". I'll have to try out to figure which direction is for high/low sensitivity. But, you get the idea.
    To turn your rain sensor off, just move the stalk/lever to the Off position.
    edit: By the way, the manual also gives a list of reasons why the rain sensor may malfunction. Damaged wiper blades, Insects on the windscreen, Salt deposits, Soiling, Cracks on windscreen. But there's a paragraph which solved 'my' problem (I get into the car when it's raining. Turn on the engine and wait for the sensor to detect all the rain on the screen and to wipe but it doesn't) about when it works. It has to be in the interval position AND the vehicle is travelling at speeds higher than 16 kmh. (my vehicle was stationary.. haha). I just moved the interval length control/sensitivity adjuster and it works again.
    Jun 2006
    Sunshine Coast
    On my Golf the least sensitive setting is closest to the steering column and the (faster setting) more sensitive is closest to the drivers door. The movement of vehicle at 16km/h does explain a lot of peoples problems, mine included you can sit in driveway in pouring rain and they don't work but drive down the road on a misty day and they fire up straight away.
    May 2009
    North East Victoria
    So pardon my ignorance, how do you activate the wipers when u r stationary at the lights and it's pissing with rain when u r on auto setting?
    Sep 2009
    Bundaberg, Qld
    Passenger side windscreen wiper... WTF?
    What is the go with the passenger side windscreen wiper on my Golf mk6?
    It won't stay where it is meant to...
    Basically it moves up the windscreen by just enough (a cm or so) so that the top of the wiper blade joint protrudes into view instead of being nicely folded out of sight.
    This is very annoying (for me anyway) as this happens all by itself without me touching the wipers. It just creeps up over time by itself.
    Wierd... think I'll superglue it to the windscreen on the weekend.
    2009 Golf MkVI 118 TSI
    United Grey - 7sp DSG, Sports Pack, Sat Nav, Blutooth, Towbar, Park Assist
    2005 350Z Track Coupe
    Ultra Yellow - Lots of mods
