Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Auto lights.
    Dec 2008
    MANSFIELD VIC
    The operation of yours are not normal.
    Glad I'm not the only one that has problems with their fog!!!
    Could be a wiring issue but most likely it'll be the coding in the computer.
    HAVE: '12 SUPERB ELEGANCE SEDAN 103kW 4x4 TDI DSG | LAVA BLUE | SUNROOF | KESSY | 3x BLINDS | PARK ASSIST | PADDLES | TINTS | NOKYA YELLOW FOGS | TOWPACK
    HAD: '09 MKV JETTA TDI DSG | SALSA RED | XENONS | TOWPACK
    Dec 2008
    MANSFIELD VIC
    I've seen that "corning function" is a selectable option via VAGCOM. I wouldn't think an Aussie car would be configured that way normally (regarding all the rules & regs on the use of fogs).
    Yes, would be good to know if turning left (left fog lights up) and if turn right (right fog lights up). If so, then that cornering option has been turned on. If that's the case and you don't want it, a dealer or someone with a VAGCOM could turn it off.
    Perth WA
    Quote Originally Posted by Jase View Post
    I thought that too but the Sports Pack option (includes foglights among other things) and the standalone foglight option on the Mk VI is marketed by VW Australia as "Foglights with Static Cornering Function" so it must pass the requirements...
    I can imagine being pulled over if a cop saw you coming around the bend with the cornering light active and pulling you over thinking that a) you were driving with foglights on b) knew it was wrong because you turned them off as you came around the bend and saw the cop and c) one of your globes has blown
    It's bad enough with the Mk V constantly being told you've left your lights on and one of your reverse lights has blown... I'd hate to be getting told all the time that one of my foglights has blown too
    | Tiguan 125TSI DSG |
    Jul 2009
    Smile
    Thanks for all your comments, most helpful! I hadn't realized that the fog lights may come on when the left or right indicator lights are on as well. I'll have to check tonight.
    Jun 2009
    Eastwood, NSW
    Quote Originally Posted by Gidget View Post
    The fog lights shouldn't come on with the indicators but only if you are turning right or left (ie. if you have the cornering function).
    Jun 2009
    Eastwood, NSW
    Talking
    Quote Originally Posted by mtj007 View Post
    The missus had a gentle "you're lights are on, dear" reminder from a lady when she got out of the Golf which had the lights on delay function active. If that reminder was from a guy, should I be worried?!!
    Jul 2009
    Quote Originally Posted by GolfAtom View Post
    I've checked my lights and with the switch in auto, the fogs do actually light up when the corresponding indicator light is on.
    Perth WA
    Yeah I checked the manual for dad's car tonight and it said they are supposed to come on with the indicator or when turning on a sharp bend so it sounds like everything is working as it should.
    | Tiguan 125TSI DSG |
    Jun 2009
    Eastwood, NSW
    Sorry, Gidget, I didn't check before making that comment.
    Jul 2009
    No problems, Golfatom. I'm still learning about the many quirky (but good) things with the 118TSI!
