Page 9 of 9 FirstFirst ... 789
Results 81 to 84 of 84
Thread: Auto Closing Sunroof & Windows Tricks and Tips?
  1. #81
    Apr 2010
    What about the seatbelt chime sensor?
  2. #82
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Frankenstrat View Post
    I think it may now be illegal to leave children unattended in a car unless you're paying for fuel at a servo.
    Yes I think it is illegal. Doesn't seem to stop in happening with monotonous regularity at casino car parks and similar venues. Anyway, while it is probably not the reason for it being inactive by default, it is worth considering possible unintended consequences if you intend to activate it.
  3. #83
    Aug 2011
    Whats the risks in doing this? Has anyone had any problems with it…
    I assume warranty is void once its done?
    I’m keen on getting it done but not sure on the above questions
  4. #84
    Feb 2009
    Sydney, Australia
    There's no such thing as a warranty being voided on a car. The only thing is that VW can't be expected to cover the warranty of parts you install, or problems they cause, or problems you cause installing them.
    In the case of this, there are no new parts, it's simply a software setting change. As long as you follow the commonsense guidelines of using VCDS, there is nothing you can do to stuff it up. However, if you do stuff up something in VCDS, you'd be liable to pay a VW dealer (or someone else) to fix it.
