Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 84
Thread: Auto Closing Sunroof & Windows Tricks and Tips?
  1. #61
    Jul 2010
    Coreying, it's actually on Page 4 of this thread (I later found it but not after fiddling around with a bit different instruction on other MK5 specific websites) ... If I had read page 4 before I wouldn't have spent 1 hour figuring out where things have moved...
  2. #62
    Mindarie, Perth (WA)
    Feb 2009
    Sydney, Australia
    Thanks... at some point we should have a sticky with a link to all these things or something... damn time
  4. #64
    Jul 2010
    that's a good idea... get all the VAGCOM codes in one place, just in case the links from other websites gone missing or deleted...
  5. #65
    Apr 2010
    Hehe, if only I enabled this feature last weekend (got a bit of H20 in the car the other day after a hot afternoon). As it turns out leather seats are a lot easier to wipe dry than cloth)
    I brought the work laptop home this weekend so I'll have to add that feature and test it.
    +1 for a VCDS tweaks sticky - I was thinking of making one the other day but was at work at the time
  6. #66
    Sep 2010
    UK
    Quote Originally Posted by rs73 View Post
    finally enabled this auto closing sunroof on rain sensor on my GTI... took a while and didn't realise needed to enable the RainLightSensor section then go back to Central Elec BCM Long Coding (2 step process), some of the bytes instruction on other forum was a bit off (eg wasn't byte 24 but was like byte 13 or 17 a lot earlier than that)... took a while to test as I didn't realised it only worked when car is being locked like when you parked and forgot to close it...
    RS73, did you do this mod on a MK5 or MK6. I asked my local garage to do this on my MK6 with the information from earlier in this thread but he said it was only for the MK5???
  7. #67
    Sep 2010
    UK
    Quote Originally Posted by MkVIGTI View Post
    The auto rain closing worked like a charm once I found out the correct conditions for it to activate. I'm also loving the recently activated cornering foglights! Thanks again Steve!
    MkVIGTI, do you have a guide how to do this, tried to get my local garage to do it but the information i gave him off this thread did'nt work.
  8. #68
    Mar 2010
    http://www.vwwatercooled.org.au/f112...ary-50749.html
    Once you get into the correct menu within VCDS, you should just tick the box and click do it.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  9. #69
    Sep 2010
    UK
    Thanks for responding.
    Apologies for all the questions but the link you posted for me, is this specifically for MK6 Golfs. Reason i aske is that the post with the information on earlier on in this thread, my local garage said that it was for a MK5 only.
  10. #70
    Mar 2010
    Quote Originally Posted by dstill View Post
    Yes it's for the Mk6. It worked for me and was pretty straight forward once you are in VCDS.
