cktsi, you're right - on hill starts applying throttle causes the brake to release and clutch to engage and you've got 2 seconds to do so before the hill hold releases brake pressure anyway and the car starts rolling backwards.
On level ground, the clutch seems to partially engages to creep the car after brake release without applying throttle so you can wait for movement and then gun it.
They seem to require a smoother throttle tip in than I would use for a conventional auto.
coastie - I was talking about the clutch, its a given that the gears needs oil. I've driven both 6 speed and 7 speed DSG's as rental cars in the UK (base spec cars mind you) and the 7 speed seemed to shift smoother when cold (I'm talking north of Manchester in winter type of cold ) which I put down to it being a dry plate clutch but who knows?
