Results 1 to 3 of 3
Thread: AirCon Question
aVex AirCon Question 02-05-2012, 04:01 PM
Klink1313 If the aircon is turned off,... 03-05-2012, 11:28 AM
aVex I've always thought it was a... 03-05-2012, 01:11 PM
    Nov 2010
    Kensington, Victoria
    AirCon Question
    Hello All
    Might be a silly question, I noticed that when I switched the AC off, the temperature controls still work? It was actually still cooling the air or heating the air when I changed the setting on the temperature dial. I've always thought that if you switch the aircon compressor off the air con will just function as a blower.
    Can someone please correct me?
    Thanks!
    Regards
    [Current] Audi A4 B8 MY2013 2.0T Quattro - Lava Grey, Black Edition, S-Line, 19" TT-RS Wheels
    [SOLD] Golf GTI MK6 MY2011.5 - Candy White, 5-Door, Manual, Sunroof, Park Assist, 9W7 Bluetooth RVC, MDI, Dynaudio, RossTech MicroCAN, Bluefin Stage 2, LED Tails, VW Racing Panel Air Filter, 3" Eurojet Downpipe, Milltek non-Resonated Catback
    Lake Macquarie
    If the aircon is turned off, changing the temp will just be changing how much hot water from the engines cooling system is going to your heat exchanger and therefore how hot or cold the air coming into the cabin is.
    If it was hot outside, having the temp setting at 16c wouldn't make the car cooler.All that would happen is that there would be no hot water going into the heat exchanger but the air coming in the cabin will be the same temp as the air outside.
    In winter the heat exchanger can heat the cold air up though.
    Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
    Nov 2010
    I've always thought it was a compressor at work, never did I realise that the engines cooling system had a part in this. In this case then it explains why when the AC is turned off and the temperature is adjusted there still is some sort of temperature change.
