Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Acceleration Hesitation
    Hi, I have a manual 2010 TSi 118 (no mods done). It has done 70K. At 60k had to have the rings replaced after I lost a cylinder. Since then the car has been running fine until the other week. I noticed a slight hesitation when accelerating while in top gear. Didn't think much of it until it started happening more frequently & it is now happening in all gears quite frequently. At times it repeatedly hesitates & I can feel the car surging trying to accelerate. If i am in the lower gears just cruising around I don't feel it until I put the foot down, then it will hesitate. Sometimes only once, sometimes multiple times. I plan on booking it in for a checkup as it is still under an extended warranty. I just wanted some advice on possible causes as I want to give the repairer an accurate fault description. Any advice greatly appreciated.
    Mar 2013
    Brisbane QLD
    Are you using 98 RON fuel??
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jan 2013
    Brisbane, QLD.
    And if so, what company are you using to fill up with?
    Yeah good point. I mix it up, sometimes 98 sometimes 95. Always have, never had a problem until now. I usually use Woolworths Caltex as there are more of them in my area. They are all on the same stretch of road. Will have to try some 98 from a different company. What are the changes of bad fuel causing this?
    Canberra
    Do you have warranty?
    The 118TSI is a very expensive engine. AFAIK VW never actually fixes them, they always replace them.
    Jun 2011
    sydney
    Could be a supercharger clutch issue?
    Quote Originally Posted by ziggyboy View Post
    I have an extended warranty.
    Canberra
    Just take it in and get it resolved ASAP.
    Jan 2013
    Brisbane, QLD.
    You are mistaken, VW replace injectors, pistons, piston rings and software update.
    To OP: Always use 98RON, especially for a CAVD as Australian fuel quality is extremely poor. CAVD in Europe is known to be a 'bullet proof engine' due to fuel quality there compared to ours. FYI
    Mar 2009
    Melb
    spark plugs?
    Tig 162 R-Line; Audi TT
