Results 1 to 10 of 11
Thread: ACC vs Audi Magnetic Ride
    May 2010
    Hey guys, don't think this has been asked before (shoot me if it has).
    Are they essentially the same? Completely different? Curious as to how they actually differ.
    Hoping WhiteJames knows!!
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
    May 2010
    Reply to my own post..haha...should have added in the reason why I started this thread. Read this from a site reviewing the Scirocco
    It certainly hits the mark. The basic suspension is from the Golf GTI, but some of the components have been made from aluminium to help reduce weight, while the wider track also improves the car’s dynamics. On top of that, the VW has the firm’s Adaptive Chassis Control (ACC) as standard. The set-up is effectively the same as the Magnetic Ride system that’s an option on the TT.
    The Audi system uses actual magnetic fields to adjust the firmness of the dampers. Is this what ACC does also?
    Feb 2009
    Sydney, Australia
    This isn't really the forum for this topic, because ACC is generic to the entire VW brand, and Magnetic Ride is obviously an Audi thing. But I too am interested in the answer.
    But being that this isn't MK6 specific, have you searched the entire VWWc forum on terms like "Adaptive Chassis Control" "Dynamic Chassis Control" and "Magnetic Ride" to see whether there are results in other subforums?
    May 2010
    understood corey, wasn't sure where to put the thread. this is really the only forum I read/post (other than the audio forum).
    I have searched....nothing specific that compares them. I end up getting tons of search results back when searching those terms...I really can't traverse through all of them.
    no worries if you need to move this thread.
    My understanding is that magnetic ride has tiny little metal particles like rods in the shock fluid, and the magnetic field (when on) orients them across the shock, thus impeding the flow of fluid and making the suspension stiffer. This requires low current and no real moving parts.
    ACC in the volkswagens appears to be a hydraulically adjustable solution.
    Not 100% sure though.
    Feb 2009
    Sydney, Australia
    Nah, it's all good... just wanted to see whether you had looked in the other subforums... hopefully someone has an answer!
    Oct 2009
    SydVegas
    Does this help? (I don't understand half of it, to be honest)
    Scirocco Central • View topic - ACC vs Audi Mag Ride
    May 2010
    good find!! I believe that sums it up quite well.
    at the end of the day, doesn't really go into which is better, etc (sure there would be some subjectiveness there)
    also thank VW for not charging audi pricing. $2400 for the magnetic ride!
    Feb 2009
    Sydney, Australia
    Oooh, so the Audi Magnetic Ride IS the Delphi system. That's cool to know. Ferrari have used the Delphi system too. Good link S.A, thanks
    Quote Originally Posted by coreying View Post
    Which kind of suggest that you could "reflash" the system to give you differing handling characteristics or match it to differing spring rates.
    HSV and Cadillac also use the Delphi system (in fact I think Cadillac was one of the first)
