Results 1 to 3 of 3
Thread: ABS/ESP fault lights
    May 2007
    Jimboomba. QLD
    Hi all, 90TSI manual. Driving around Brisbane in the rain today. Just driving along and the ABS/ESP fault lights come on.
    No big puddles, pot holes etc, on the motorway when they come on.
    What are the chances that water has got into a connector somewhere? If it dries out, will the fault lights go off.
    Any obvious places I should start looking before finding someone to scan it?
    ABS/ESP fault lights-20240405_123809-jpg
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Possibly a faulty/damaged wheel speed sensor (also known as an ABS sensor) - very common on the Mk5 and Mk6 and causes the errors you have got.
    Assuming this is the issue, its a cheap fix and easy to replace.
    You will need to use a scan tool to find out which wheel has the issue, because they have different part number (and shape) wheel speed sensors depending on front axle/rear axle and left side/right side.
    Brake Discs | Brake Pads Australia Wide Shipping | Run Auto Parts
    May 2007
    Jimboomba. QLD
    Thanks Lucas, I'll get it scanned.
