Kieran_2 I noticed throughout your fault scan that you have this error mentioned several times "Throttle valve potentiometer-G69 signal too small"
This error points to an issue with the throttle body valve (or, in the case of a diesel engine, its probably blocked with soot and needs a good cleaning with carby cleaner and various brushes). You might want to have a look at this as it seems to be linked to your ABS control module issue.
00290
Raw code: 0122
ECU: 03. ABS control unit
Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
