I am aware that the new GTI runs fine on 95RON as the recommended petrol.
However I also know that 98RON is cleaner and apparently gives superior mileage.
Does anyone have any comments on whether pumping 98RON fuel would actually be beneficial? Is the extra cost (15c difference in my area) actually justified?
2011 Audi A5 Sportback 2.0TFSI S-Tronic Quattro | Deep Sea Blue | 18" Audi exclusive 10 spoke | Bang & Olufsen | MMI Plus Nav | Advanced Parking & Reverse Cam | Sunroof | Sports Suspension | Xenons | Walnut Inlays || Previously: MkVI GTI | Carbon Steel Grey | DSG | ACC | Dynaudio | Reverse Cam | "R" LED Tail Lights | APR Stage 1
Yes its worth the extra money.
Lower octane petrol makes the car less powerful and over time will crack manifolds and damage other parts due to its hotter burning.
You get a leaner, more efficient burn with the higher octane, especially in a Turbo car. It will go further on the higher octane, so it will end up costing the same.
Worth remembering also that Australian 95 is 3rd world standard of petrol and is probably about 91 octane in German terms.
Its an expensive car, if you are gonna cheap out on the petrol, you should buy a Camry.
Thanks for the reply. I should clarify that the question was meant in the context of the new gti's engine only. I'll stick to 98ron as expected!
BP Ultimate all the way for me - never used anything else since new in my Euro, nor will I do with my GTI. Definitely worth the extra price based on what I've read.
(Not meaning to turn this into a fuel war.)
Why wouldn't u use 98..
Driving interstate through some backwater towns you may find it difficult to find 98Ron fuel.
That is the only reason i can see for not using 98Ron.
However if you were smart you would fill up in the bigger backwater towns and plan your trip around this/carry a jerry can.
98Ron is the way to go!
One review I read touted the GTI's ability to run on 95ron as a marked saving to the hip pocket. Not being a mechanic I was wondering if this ability came from mods to the engine which protect it and allow just as good and safe perormance from less pure petrol. If this was the case, I'd stick with 95. Those that shout from above still say 98 for sure, so I'll follow their advice.
It's good to know it can run on 95 if you get stuck, but 98 is still the way to go - pay a bit more at the bowser but get better performance and economy.
