Fuel standards in Europe (along with most aspects of economic activity) are determined by the Comité Européen de Normalisation (CEN) or European Committee for Standardization. And the relevant standard for petrol or gasoline is Norme Européenne 228 ( EN 228 ) or European Standard 228. Diesel is covered by EN 590. As far as I'm aware, these standards are not legally binding by themselves, but most Member States (UK, France, Germany, etc.) adopt these standards as part of their legislation, which then become law (European bureaucracy at its finest).
In the UK, France and Germany most petrol is sold as 95 (regular unleaded/sans plomb 95/Superbenzin) and 98 (super unleaded/sans plomb 98/Super Plus Benzin). But weirdly, in Germany, 91 (Normalbenzin) is also freely available, though I believe it's slowly being phased out.
In regards to quality, comparing EN 228 and the Fuel Quality Standards Act 2000, one notable difference is the sulphur content. From 1 January 2009, petrol conforming to EN 228 is limited to 10 mg/kg (10 ppm) and designated as "sulphur free". Australia in comparison has a limit of 50 mg/kg (50 ppm) for 95 & 98, and a whopping 150 mg/kg (150 ppm) for 91. Sulphur content is an issue particularly for direct injection engines, because DI engines can operate under "lean-burn" conditions which reduces fuel consumption. "Lean-burn" conditions create excessive nitrogen oxide (NOx), one of the regulated pollutants. This is dealt with by using three-way catalysts (TWC) which, very simply, "stores" as much NOx as possible until the engine momentarily runs rich, providing excess fuel which eventually converts it to harmless nitrogen. But as sulphur compounds are chemically similar to NOx, they compete for storage space, quickly "filling up" the catalyst, decreasing its efficiency and inducing frequent "rich" runs, thus increasing fuel consumption - one reason why you'll never see the full economic benefits of lean-burn technology here, and probably why the SIDI engine in the Commodore isn't as fuel efficient as it should be (amongst other reasons).
Research octane number (RON) and motor octane number (MON) for are identical for both standards, set at a minimum of 95 and 85 respectively. In Sydney, 98 is only 5 cents dearer than 95, so totally worth it IMO. Though I noticed at volkswagen.de that the new Golf R can use Superbenzin 95 RON, but to achieve maximum performance Super Plus Benzin 98 RON is required. But nothing is mentioned for the GTI, other than to use Superbenzin 95 RON.
And in the latest version EN 228:2008 (superseding EN 228:2004), "Premium unleaded petrol” becomes “unleaded petrol”, probably because 95 and 98 have been the main sellers in the EU for some time. I think this is what Dear Moderator is referring to - just a wording issue, nothing more. Though it is also noted that Member States "may decide to continue to permit the marketing of unleaded regular grade", with a minimum RON and MON of 91 and 81 respectively (likewise in Australia). Hmmm, a get-out clause for the less well off Member States perhaps...
So in terms of engine performance our fuels are comparable to European fuels, but in terms of environmental performance we still have some catching up to do. And for other lurkers with European cars considering using 91 instead of 95, for goodness sake don't! There's a reason why it's so cheap!
