Very common. A water pump is often a very cheap part, but may require the timing belt be removed in order to fit it. I've read that it's common to replace the water pump when the belt is changed (assuming the engine uses a belt and not a chain), because the work is being done anyway and it saves the risk of a cheap part going and requiring a stack of labour to replace down the line.
