I think you will find its the supercharger, it does it to me even in the manual sometimes.... The supercharger will sometimes cut in after a gear change if the revs are low but then instantly think its not needed if your being easy on the gas and therefore cut out. The the quick pause your feeling for a literally a second is the time between the supercharger cutting out and the turbo coming on boost.
Take it out into a REALLY quiet area, probably at night time and see if you can hear the supercharger or the supercharger clutch (the clicking sound as it cuts in and out) following the trend mentioned above, I think you will find this is exactly what it is. Also listen for the slight whistle (or whoosh) of the turbo directly after.
Stoney!
6 Sp Manual 118 TSi
Colour: United Grey
Build Date: August 09 Delivery Date: 16th Oct 09
ODO at last fill: 2555km
Avg Fuel Cons at last fill: 8.6
