Good Day ( Apologies to those seeing this thread again
I purchased a golf with blown CAVD motor then replaced it with a CTH motor. Before I noticed the fuel was on E. On road test I went to the servo and filled up with $10
I checked for codes, then measuring blocks. The gauge resistance is said to be 510 ohms. I did not pull the pump unit out because When I unplugged the pump and relay, I was expecting an open circuit fault on the cluster module but the fault remained the same (resistance too high). The vehicle has one pump module/ gauge (or at least that's all I could see). I tried to do adaptation as per Wiki but the menus and options to define resistance etc were not popping up. The access code on wiki was denied by the module. Not sure what to do next.
Code:
Wednesday,22,July,2020,16:30:08:41695
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZAW187659 Mileage: 86100km-53500miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 870 D HW: 5K0 920 870 D
Component: KOMBI H05 0206
Serial number: 00000000000000
Coding: 770B00
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2E1000A071B59AF6A9-807A
1 Fault Found:
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 86108 km
Date: 2020.07.22
Time: 01:53:22
Address 09: DTCs cleared
Control Module Part Number: 5K0 920 870 D
Component and/or Version: KOMBI H05 0206
Software Coding: 770B00
Work Shop Code: WSC 01357
Advanced Identification/FAZIT
Identification: VDD-024
Date: 14.10.09
Manufacturer number: 1901
Test stand number: 3405
Flash Status
Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
Programming Status: 00000000
Flash Date: 00.00.00
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
HiSpd Net: 01.10.00
Misc.
Hardware number: 5K0 920 870 D
Workshop System Name: J285
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A04040
Car Info
Chassis Number: WVWZZZ1KZAW187659
VCDS Info:
Labels: 5K0-920-xxx-17.clb-SRI1
Date: 14.10.09
Flash Status
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
HiSpd Net: 01.10.00
Misc.
Car Info
VCDS Info:
Address 17,5K0 920 870 D,channel IDE00493-Display correction of fuel gauge,adapted from,0.0 ,to,120.0 ,
Address 17,5K0 920 870 D,channel IDE00493-Display correction of fuel gauge,adapted from,-8.0 ,to,510.0 ,
Address 17,5K0 920 870 D, channel IDE00493-Display correction of fuel gauge, adapted from,-2.0 ,to,0.0 ,
UDS Adaptation Channel (1B): IDE00493-Display correction of fuel gauge
Stored value 0.0
