I ended up finding this thread (which was posted on the same day, talk about perfect timing) and I followed his lead in dremel-ing the plug to fit it. No damage was done to the actual sensor part inside.
Take a pic. I have mine to install on the same engine.
Thanks
With the 1.4 118 tsi vehicles I wouldnt buy anything older then 2013 personally, though they have fixed most issues a little before 2013 id have a buffer yr between.
I personally would never buy ANY DSG VW as I have seen more DSG issues then 118 issues.
Regardless I guess a 118 is a gamble, but also keep in mind that the engine code has changed which means they actually have changed some sort of the build, characteristics or materials of the engine. Older engines CAVD - Newer engines CTHD.
I guess I will find out.![]()
Im enjoying it at the moment 12000ks in 3 months only window regulator is squecking. will fix it at 1 st service
2015 1.4 118 TSI Manual Jetta - APR CAI - GFB Diverter Valve - WORK SEEKER SX 18X8.5+35 - Muffler Delete - BC Coilovers - RCD 510
Hi all,
Have owned my 2010 118 TSI from new (now 60000kms on meter) and struggled with a few minor issues throughout ownership. Well maintained and drives well at present. Having read all the horror stories on this forum about engine and gearbox failures, I'm kind of thinking of moving it along before disaster strikes bigtime. Issues I've had and resolved:
1) 'Chirp" from supercharger water pump - fixed about 12 months into ownership
2) DSG and mechatronic failure - mechtronics replaced DSG reflashed (covered fully by VW about 3 months out of warranty), told cost was approx AUD 4500
3) Various recalls - 2 from memory
4) Various squeaks and rattles - one particularly bad one from the fuel pipeline tapping against the body - all fixed eventually
5) Air con compressor replaced - out of warranty
Main source of worry would be the engine or gearbox. Just wondering what other owners have done and if moving it along at the 5-6 year mark is a good option while the going is good? Or is it worth the risk of keeping and running it to the bitter end?
Thanks all. Superb forum.
I've been tossing up the idea of selling too. Have always kept our cars 10yrs+ in our family but I'm getting worried with the 118tsi nearing 100k kms. I really wish I had the 147tsi jetta instead.
Sent from my E6653 using Tapatalk
'09 mk5 Jetta 118TSI
'11 C7 A6 3.0TDI
'11 B8 A4 3.0TDI - RIP
Thanks for the reply, have had a chat to my usual VW specialist mechanic here in Brisbane and they are advocates of selling early rather than be faced with repairs approaching the value of the car.
I can't seem to find this bit of information anywhere. Where is the intercooler located on a Mk6 118TSI? I doesn't seem to be front mounted (from what I can tell).
Any help would be appreciated!
Front mounted in between the radiator and a/c condenser.
