Page 7 of 58 FirstFirst ... 567891757 ... LastLast
Results 61 to 70 of 573
Thread: 118TSI - General Discussion
  1. #61
    Dec 2009
    Quote Originally Posted by mk6tsi View Post
    Hi guys,
    Just got my Revo Stage 1 ecu upgrade today, i was intially intending
    on getting the apr stage 1 ecu upgrade as there is a xmas special with them
    at the moment as well. But as i found out when i went to get it today was
    that there wasn't any software for my car just yet? Even tho APR claimed on there website that the mk6 1.4 tsi twincharger ecu was availiable, The guy claimed that all ecu are different and all have different codes so i'd either have to wait till someone with same coding as mine got it first then ill be able, or i take my ecu out and send it to brisbane to get my ecu reflashed and be without a car for 1-2 weeks.
    Apart from that problem with apr not being able to offer me the reflash the Revo stage 1 is quite good. Intially took about 30mins to do the install.
    Alot more torque/power .
    No more lag from stop.
    Nice rumble from exhaust now.
    Just having a look at http://www.revotechnik.com/products/...aspx?pvID=1196 and they claim a power increase to 163kw - is that for real? The others (APR, Bluefin etc) are all around the 150kw mark.
    Did you get it from Peak Performance? Can you switch it back to stock mode easily?
    Black Golf Mk VI 118TSI Manual Sports
  2. #62
    Dec 2009
    Post
    Quote Originally Posted by cwcarruthers View Post
    The ONLY issues are:
    1) Really, really annoying rattle in the driver-side door (maybe B pillar). Almost a squeaking between two materials, but rattly, if I put my arm on the arm rest, it stops. Only shows up on coarse-chip bitumen.
    Does anyone else have this, or have any suggestions for fixing it?
    It sounds like it is perhaps on the passenger side as well, but it's hard to tell when driving by myself!
    2) Slightly less refined when the aircon is on, in that there is more shudder when moving slowly from a standstill (e.g. parking).
    Hi,
    I just picked mine up. Black Sports pack, RNS-510 with dynaudio, RVC, Fiscon bluetooth, sunroof and park assist. Love it!
    However, i have discovered 3 issues with the car already.
    1. The door rattles on the driver-side. Has anyone gotten this fixed?
    2. The rear windscreen seems to leak washer fluid whenever i use the front windshield washer fluid
    3. My RNS-510 doesn't accept SDHC when the manual says it does.
    Hopefully this is all covered under warranty
  3. #63
    Sep 2009
    Melbourne, Victoria
    Quote Originally Posted by Liquid View Post
    Hi,
    The rattle is very annoying. I would love to know of anyone that has this fixed, and what the issue is. I have mine booked in to get looked at next month - hopefully it can be resolved.
  4. #64
    Feb 2009
    Sydney, Australia
    1. A few MK6 owners have mentioned this around the forums. I'm sorry, but I haven't paid attention to whether they've had it fixed.
    2. My MKV did that as well. It happened just after the washer fluid container was filled and then was ok after a day or two (of usage of the washer fluid).
    3. Just get the dealer to do the flash upgrade of the RNS-510 and it'll be fine
  5. #65
    Jan 2009
    nsw
    my auntie just picked a mk6 118tsi sports pack a few weeks back and i got the chance to drive it last week. Very nice car! I REALLY like the interior especially the dash! makes the interior of my mk5 look abit dissappointing =\ i didn't quite like how the aircon vents look this time around thou... The suspension and ride is good and when driving, i couldnt even tell i was going faster then what i thought i was going alot of the time! very impressed from a little 1.4l
    however i think the launch control on these things is pretty gutless. A tune on one of these things would make it alot more enjoyable imo but trying to encourage my aunty about that is another thing since she 'thinks' its already too fast for her already hahah
    I still enjoy my GIAC'd pirelli ALOT better thou =P
  6. #66
    Mar 2009
    Melb
    Mine rattled early in the ownership but it sort of just went away over time (mine's nearly 20,000km). On the Italian VW forum, there was mention of door trim rubbing aganst the B pillar but not sure if this is the case with mine.
    Happens to every Mk 6. Have to live with it unless someone puts in a valve it wouldn't go away
    Firmware updates to 2660 as on mine allows SDHC. I use a 12 GB SD card on mine.
    Hope this helps
  7. #67
    Dec 2009
    Quote Originally Posted by mr gee View Post
    Hope this helps
    Thanks mr_gee, bit annoying to see some washer fluid leak, but its not as annoying as the door rattle for a new car.
    re: RNS-510, how do i know what version i'm running? and will the dealer upgrade the firmware?
  8. #68
    Mar 2009
    Melb
    on some versions, you press the setup button for more than a minute. it will first display the setup menu but continue pressing and it should then display a supplemental menu that shows version info amongst other things.
    Maverick has a website:
    http://www.my-gti.com/category/in-ca...-entertainment
    alternatively,:
    http://vwnavi.com/forums/forumdisplay.php?f=51
    mine looks like this:
  9. #69
    Feb 2010
    Do the GTI's have the same issues?
    Are these problems peculiar to the 118TSI's? Does anyone with the MK6 GTI's have the same problems? I am still undecided whether to go for a highly spec 118 TSI or a basic GTI. I seem to be getting the feel that the GTI has less issues.
  10. #70
    Jan 2010
    UK Cheshire
    Quote Originally Posted by Stelex View Post
    It goes like this. You're standing, then you press accelerator. it pulls normally for a second, then switches into the second gear. When this happens, there is a painful moment of about 1-1.5 second where there is barely any power, it feels as it is litteraly choking, like there is no fuel supply, (yes, it's because the very low revs), but then it goes smoothly afterwards. This is very painful when joining busy traffic. Very frustrating.
    If I press the accelerator hard, either from a stand-still or from when I first notice that it's choking, it just goes wild.
    Had this on my new Scirocco 1.4TSi DSG. DSG is always adjusting to your driving but just sometimes it gets beyond self-recovery, Under these conditions th eonly way out is to reset the box and make it re-learn.
    Did the 7speed DSG "reset"/basic learning to mine. Drove it straight afterwards in DSG "D" mode from start all the way through the gears to 7th and back down - speeds 0 - 70mph. All the problems above now gone, right foot now feels connected to the wheels. Very smooth in all gear changes and no real lurching anymore or fluffed take-offs. Gears are more sensibly selected by the DSG as well for the driving conditions.
    Reset on 7 speed DSG:
    With Engine and Gearbox at or near the normal working temperature.
    No igniton on, key out of steering lock. Press accelerator full home until the switch is felt at the bottom and hold it with the switch "on" for 10+ seconds. I used 20 seconds to be sure.
    Now drive it normally in DSG "D" mode but ensure you drive this sequence. In the first few minutes take it from low speed (20mph) all the way upto 70mph and 7th gear and then back down to a stop. Coming back down can be the next junction a couple of miles down the way so no need to block the highway. Let it creep at 5mph-ish under no throttle condition while in 1st gear for a few feet (20 feet) to learn that. Job done.
    C.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
