Page 46 of 57 FirstFirst ... 36444546474856 ... LastLast
Results 451 to 460 of 570
Thread: 118TSI - General Discussion
  1. #451
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Kiark View Post
    How much slower is the 103TDI compared to the 118TSI? Would it be an obvious difference?
    The 103TDI is actually faster than the 118TSI, factoring in when you get the check engine light on the 118tsi with no compression the 103TDI blows it away. No power on freeway is not fun.
  2. #452
    Jul 2011
    AU
    Yeah if you ask the VW service guys, they know the score. They know which cars have problems and which generally don't. Most of them will say get the diesel, it will go for 300,000 generally without any major issues. Even better, get the 6 spd manual. But the 6 spd DSG is still a pretty reliable transmission generally speaking
  3. #453
    Jul 2011
    Epping, NSW
    If you want the most reliable vw combination, it'd be a diesel like the 103TDI and a manual gearbox. If I were in the market to buy again, I'd stay away from the 118TSI just because of the horror stories. Great car if it works, but with the amount of people reporting issues, I'd stay safe and avoid it. Save a little extra for a GTI or get a 103TDI and an ECU tune.
    '09 mk5 Jetta 118TSI
    '11 C7 A6 3.0TDI
    '11 B8 A4 3.0TDI - RIP
  4. #454
    Jul 2011
    AU
    I am starting to look around for possibilities for my new car when my lease runs out next year. I was thinking of a Tiguan 4x4 diesel manual, until I found out they don't sell manuals anymore!
  5. #455
    Quote Originally Posted by Tobes_WIR35 View Post
    Tobes the 4x4 Tiguan has the DQ500 "wet" 7 speed DSG which is the same gearbox that is used in the Audi TT-RS and Transporter. It's been designed for the high performance and heavy duty applications with a max torque of 550Nm. This is pretty much bullet-proof and completely different box to the DQ200 "dry" 7 speed which is used in the lower power Golf and Polos.
    Yes manual is a safer option if you're going to hang onto it long term. That's why you'd buy a Mk7 90TSI manual. Otherwise you just need to get on the new car merry-go-round and upgrade every 3 years before the warranty runs out.
    Jul 2011
    AU
    Yeah I'm aware of the DQ500, I was more keen on a manual just for driving experience really... Been driving auto/DSG now for about 7 years so just thought of a change... that being said I do like the DSG so it's not a huge loss
  7. #457
    Trinidad and Tobago
    Would be interesting to find out why VW's implementation of the DQ200 was so bad. I suspect it's down to the suppliers/poor design as opposed to an inherent flaw in dry clutch DSGs. The one common thing amongst the other VAG group DSGs that work is that they aren't made by LUK.
  8. #458
    Jul 2011
    AU
    I think the other DSG's are made in house or in a partnership with Borg Warner? DQ200 is bought in crates by VW I think. Probably the last time they'll do that for a while!
  9. #459
    From my basic understanding, the DQ200 generates too much heat which it can't dissipate properly and ends up cooking itself.
    This is made worse by how much the gearbox "rides the clutch" in slow speed traffic. If you're caught doing a lot of crawling the DSG will slip the clutch to keep everything nice and smooth, however this generates a lot of heat. With the gearbox running "dry" with only a small amount of oil there's not so much fluid to transfer the heat. To make things worse, the electronics are mounted right nearby and this ends up getting cooked along with the gearbox itself.
    Jul 2011
    AU
    Interesting... sounds plausible. Do the wet DSGs have any sort of external fluid cooler?
