i not too worried about it seeing as though its 'meant' to do it. when i got the plugs changed, it stopped doing it but then started again. Not sure whats going on there though.
I just sold my 90TSI.
I loved it to bits. Only problem, needed a bit more power (Even with a Stage 1 ECU from Superchips).
With the cash and about $3k out of my pocket, I can pick up a 2nd hand 118TSI.
Really enjoyed this thread, and thank you to all that participated. You have really helped a lot.
Welcome to the Supercharged club
Yes welcome.
MY11 VW Golf 118tsi, Silver, 6 Speed Manual, MDI, RCD510 touch screen, tinted windows.......more to come.
Geez Stelex you've had a bad run. I've got a '10 Golf 118TSI DSG with Sport Pack and have had many of the same problems... short of the engine blowing up. I'm going to start a new thread to discuss the 7 speed DSG hesitation and get a feel of what percentage of people are having this problem. I guess I can count you in the "yes" column.
I don't see this kind of unpredictable behaviour as something we should be getting used to as many people have suggested (including VW employees). Besides, they had 6 speed wet clutch gearboxes available which work pretty well and instead chose to make a car with this thumpy unpredictable mess. This is my third VW but it's only been getting worse as I've moved up in the family. Certainly not buying another VW if this is the sort of car they're going to release into the wild.
And it continues ...
After my last post just before Christmas they have replaced the Mechatronics. I have received my car back on 31/12/2011.
Since then:
The air conditioner started hissing again and the air compressor is getting loud, clear signs of low gas pressure.
Something (most likely the DSG) is making a short (2 sec) grinding noise every so often when turning left and accelerating in 3rd or 4th gear at low revs.
Thankfully my airconditioning works... for now. I get that grind in most gears at low revs but worst in 3rd and 4th. It sounds the same as the noise I get shifting down into third which is why they replaced my gearbox but it came back after 3 months. I'd hate to have a car that wasn't made by a replutable brand
Also, left you say. Most of my troubles are turning left too.
*Sob* My lil golf is only 8 months old & all the plasticky things are started to break/crack... Dealer will only fix 3 out of 5 items under warranty. The VW Headoffice are useless. Who knows what is going to break next. Surely all these things aren't a coincidence?? it just seems like a lot at one time...
Any ideas of what I can do??
• Broken pre-set channel radio button (warranty)
• Steering wheel -button cover to change volume/channels (warranty)
• Headlight switch -cover cracked (warranty)
• Rear passenger air con vent handle thingy.. to change direction of air flow (Not Covered)
• Front Grille, a plastic strip is cracked (Not Covered) - only covered if it was under 1000kms apparently.
So disappointed... waited 6 months for delivery & now 8 months later, it's falling apart.
What have you been doing in your car?
Sorry to hear that, but that's very rare and VW honestly must be thinking the same thing.
http://www.youtube.com/watch?feature...NfRKwa0#t=353s (you'll have to ignore the other language, best I could find). Skoda/VW trim is essentially the same atm.
