Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: 118TSI Engine Failure - nothing more, nothing less, just numbers/details
  1. #31
    Quote Originally Posted by ziggyboy View Post
    The simple answer is even if it was the worst engine in the world VW will never admit that it was a failure.
    What I'm trying to say is that we may never really know all the reasons for dropping the engine
    I totally agree, dropping it for reliability concerns was just my opinion.
    Respect for the concept behind this engine aside, if I ran the company and was in charge of the bottom line I'd be dropping it quick smart from the line up too. VW won't make a cent out of many of these cars that have had major engine issues.
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
  2. #32
    Jun 2008
    Ringwood, Victoria
    In all honesty the concept is good, it's just a couple of areas that it falls down, namely piston and ring tolerances to bores and fuel delivery, all in the name of economy. There are examples of the twin charged 1.4 putting out reliable figures of 250kw+ and 350+Nm of torque. I speak with a few guys in the uk that have examples of this engine in some pretty manic states of tune and after discovering upon a strip-down the poor manufacturing of the piston/bore tolerances, all their oil consumption and blow-by issues disappeared. I'd be more concerned about the dsg bolted to the bum of the engine frankly!
  3. #33
    Sep 2009
    Quakers Hill, NSW
    2009 118 TSI 46000 kms 2.5yo no 4 cracked piston. Engine, injectors, intake flap under warranty. Now 56k fine, doesn't use oil, smooth as silk.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
  4. #34
    Do you really know this as fact? Or are you just assuming this the same way the previous poster assumed it was dropped for reliability concerns?
    Go look through the articles on the new MQB chassis ... it tells you there what that did with the engines to make them fit and reduce weight. It's essentially a totally new engine.
    The EA211 engines are a completely new four-cylinder turbocharged and direct-injection TSI engines. Compared to its predecessor, the EA211 series is significantly more compact, with installation length 50 mm shorter, thus offering more interior space. The installation position of the engines has also been optimised. Just as in the diesels, the petrol engines are now mounted with the exhaust side facing backwards and tilted at an angle of 12 degrees. The weight of these petrol engines made of die-cast aluminium is only 97 kg for the 1.2 TSI and 106 kg for the 1.4 TSI. The crankshaft alone became lighter by 20 per cent; the connecting rods lost 30 per cent of their weight. In addition the connecting rod bearing journals are now hollow-drilled and pistons now come with flat bottoms, all of them optimized for lower weight. Regarding thermal management, the EA211 petrol engine is equipped with a modern dual-circuit cooling system. That means that a high temperature circuit with a mechanically driven cooling pump cools the basic engine, while a low temperature circuit flows through the intercooler and the turbo-charger casing. The cylinder-head circuit heats the cabin's interior. The exhaust manifold is integrated into the cylinder head, enabling the engine to warm up more quickly, in turn making heat available quickly for the passenger cabin. At high loads, the exhaust is cooled by the coolant, lowering fuel consumption.
  5. #35
    Jul 2012
    Mine's a 2011 model 118TSI DSG. New clutch pack replaced at 15,000km service (campaign 37G7) after shuddering and hesitation. Pistons, timing chain and other parts replaced at 30,000km service after rough idle. Found to be low compression in cylinder 1 and excessive damage to piston.
    Just a running count, I'm the 6th person in this thread reporting in with major engine work done.
    adhock (engine)
    Ryanr_r (dsg not counted)
    Mountainman's brother (engine)
    jayjay (engine)
    Sentinel (engine)
    cme2c (engine)
  6. #36
    Apr 2010
    Good news (at least for others) is I've driven the Mk7 103TSI DSG7 and I reckon they've cracked it, driving characteristics are much better now. That said my plan is to wait for the DSG6 GTI.
  7. #37
    Feb 2013
    northern Perth WA
    I've trawled the two top 'engine gone bad' threads, and will post the results shortly (checking I haven't duplicated etc). Somewhat more than 6, somewhat less than 500. Lots of duplicated posts over threads lessens the numbers.
  8. #38
    Jul 2011
    Quote Originally Posted by adhock View Post
    You would only be counting forum members regarding engine failures. I'd like to see the amount anyway out of curiosity. I'd at least triple that amount not including members.
    But not to be harsh i still give credit to Volkswagen AG for repairing these failures under wty even though the owner is greatly inconvenienced. But they will never admit poor build quality and vw technical always question owner of what fuel was used!!! As if to point the blame elsewhere.
  9. #39
    Feb 2013
    northern Perth WA
    And if I trawled the Whirlpool forums I'd get more as well. But I couldn't be sure they didn't overlap - same people, different login id in part.
  10. #40
    Apr 2010
    The idea is still great, the biggest problem was probably building it to a price. If they applied it to a more expensive car, say twin-charge a Golf R, they could perhaps afford to engineer it better.
    But compared to something like a Honda VTEC engine where you never hear of one going bust, the 118 looks awful.
