Hi Guys,
Long story short - Dead 2009 118TSi manual with a CAVD engine. Looking at replacing it with a 2012 CTHD with 9,000km.
The above depends on what else I need. So I've been told I need to replace the ECU. To replace the ECU I also need to replace the cluster, lock barrels and keys which I'm ok with (ECU, cluster, locks and keys is between 400 to 600 bucks)
the bigger issue is the wiring harness. A mechanic advised the harness PINS may have different allocations, and even though the connector (60pin) look the same and share the same part number, the PIN allocations are different. This drove me to call up VW Spares to get some part numbers... Below is what I have:
1. 2009 118TSi (Engine code: CAVD) Manual - Harness part# 03C972619BA (My dead car)
2. 2012 118TSi (Engine code: CTHD) DSG - Harness part# 03C972619DD (Replacement car)
3. 2012 118TSi (Engine code: CAVD) Manual - Harness part# 03C972619CL (one I picked off ebay - Note that its a 12/2012 build with a CAVD engine!!!)
Can anyone confirm if the PIN allocation on the CAVD and CTHD are different? does anyone have a 2012 118tsi with a CTHD engine that I can grab their VIN number to get the harness part #? or is willing to call up VW spares for the part number?
I am starting to think I'm going to have to BIN the car and take a big loss!
![Face Palm](https://www.vwwatercooled.com.au/forums/images/smilies/facepalm.gif)
Thanks heaps.
