![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Mk R
I've not had timing chain issues but I would expect some serious internal destruction if it suddenly failed. You may have decompression loss from a cracked piston too. A compression test will let you know.
If it is timing belt related and you have not had your pistons replaced to the revised post 2012 version or a forged version then you should consider having that done at the same time. that will up the price further so you may wish to consider just getting a whole central engine block swap from a wrecker from a 2012 or later donor car. That will likely end up being cheaper...
$2800-3500 is a reasonable estimate for a central engine block replacement. About $1500 labour and sundries and $2000 for a used engine.
I'm not sure that they suggested that it failed. The reason for the engine light was either not fully disclosed or not fully known - they would know exactly what the code was, but I guess not exactly what it implies.
The engine is original so no piston replacement/forging.
I'm hoping that limp mode came on here as a preventative measure to engine damage, not as a result of it - not sure whether this is naive based on the experience of others. I didn't talk to the service department at all, so I'm not sure whether there was any mention of potential engine damage.
MY10 Golf 118tsi DSG | MY07 Polo GTI
