Cut and paste the script from notepad on the laptop is how I would do it.
Hi All,
I would like to get some advice on fixing a coding error in my Mk6 GTI and think it would be useful to attach VCDS output. I've looked through the FAQs to see how best to do this but can't find the recommended way to do so.
Advice on how best to do this would be appreciated.
Cheers.
Thanks for the response h100vw. I was wondering if there was a way to get around the post character limits but still be able to post the entire VCDS output.
Tried the embed as Code and as html but neither of these seemed embed the pasted text in a code box as happens on some other forums. Is there a different technique that you like to use here?
Just cut the part for the unit with the bad coding.
What's the problem that you have?
I was going to suggest the code tags, but I haven't tried really long form text in a while....
From the test below, you do get 10,000 characters, so maybe split it into two if needed? My last log (that I can find) is only 8,697 so would fit, and even something twice as long should be easy to split to two posts.
Code:Monday,29,November,2021,16:15:14:35849 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.9.0.2 (x64) Data version: 20210903 DS330.0 www.Ross-Tech.com VIN: XXXXXXXXXXXXXXXXX License Plate: MRSHWK Mileage: 225580km-140168mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 7H-VN75 (6N0) Scan: 01 02 03 04 08 09 10 15 17 19 25 69 VIN: XXXXXXXXXXXXXXXXX Mileage: 225580km-140168miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 69-Trailer -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb Part No SW: 03L 906 022 GF HW: 03L 907 309 K Component: R4 2,0L EDC H32 9130 Revision: 26H32--- Serial number: 00000000000000 CVN: C8DA09CF Coding: 01254012232400080000 Shop #: WSC 23117 959 96126 ASAM Dataset: EV_ECM20TDI01103L906022GF 002008 ROD: EV_ECM20TDI01103L906019DG.rod VCID: 6FE724D2B61105F1A8-803A VINID: 9E60AAAAA1D8A9160210400910788D7F80 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb Part No SW: 0BT 300 045 F HW: 0BH 927 711 B Component: DSG DQ500-7F H02 0711 Revision: 00H02V01 CVN: 00CA3CC6 Coding: 0014 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMDQ500021 001001 ROD: EV_TCMDQ500021_001_VW37.rod VCID: 3875DF8E83DF8249B9-806C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb Part No SW: 7E0 907 379 E HW: 7E0 907 379 E Component: ESP MK25A XT H43 0103 Revision: 00H43001 Coding: 108724AD09A8089924A2907AAA6216 Shop #: WSC 02756 790 49152 VCID: 346DEBBE97B7662995-8060 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb Part No SW: 7E5 907 040 H HW: 7E5 907 040 H Component: ClimatronicT5 H10 0101 Revision: 00002001 Coding: 0002001102 Shop #: WSC 02757 790 50316 ASAM Dataset: EV_ClimatronicT5 A01002 ROD: EV_ClimaAutoT5Basis.rod VCID: 2D5BFEDA7C9D37E1DA-8078 Slave 1: Subsystem 1 - Part No SW: 7E5 907 049 A HW: 7E5 907 049 A Component: Heckbedienung H10 0101 Serial number: BHB-0010302100010141 1 Fault Found: 9481200 - Refrigerant Pressure B10AB F0 [008] - Too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 231 Mileage: 225439 km Date: 2021.11.29 Time: 14:51:36 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb Part No SW: 7H0 937 087 B HW: 7H0 937 087 B Component: BCM T5GP H+4 H46 0207 Revision: BO046001 Serial number: 0156 044100618 Coding: A0A0293A0E61240393204000242B8FD40080410F60040000300000000000 Shop #: WSC 02756 790 00000 VCID: 336FE8A292B961118C-8066 Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 090210 05 54 0403 Coding: 03302E Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB Component: J386__TSG_FT 002 3310 Serial number: -------------------- Coding: 010000 Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB Component: J387__TSG_BT 002 3310 Serial number: -------------------- Coding: 000000 Subsystem 4 - Part No: 7E1 951 171 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 5 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 Subsystem 6 - Part No: 7E1 951 171 Component: DWA-Sensor 00 001 0104 Coding: 000000 1 Fault Found: 03303 - Response Closing Status of Rear Left Door 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 223 Reset counter: 232 Mileage: 218891 km Time Indication: 0 Date: 2016.03.29 Time: 09:10:15 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb Part No SW: 7E0 919 475 A HW: 7E0 919 475 A Component: PARKHILFE 8K H10 0008 Revision: -------- Serial number: 32730921101878 Coding: 010101 Shop #: WSC 30114 831 1247424 ASAM Dataset: EV_VW75XParkAssis8K A01003 ROD: EV_VW75XParkAssis8K_A01.rod VCID: 3065E7AE6BAF5A09F1-8064 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 7E0 959 655 HW: 7E0 959 655 Component: VW10Airbag02E H05 0011 Revision: -------- Serial number: 003E4000BAED Coding: 000000000000000000000000000000003245 Shop #: WSC 02754 790 50316 ASAM Dataset: EV_AirbaVW10BPAVN750 A01001 ROD: EV_AirbaVW10BPAVN750.rod VCID: 73EF28A2DA3921114C-8026 Crash sensor for side airbag: driver side: Serial number: 3495ZRB405B6094IH0NJ Front Passenger's Side Airbag Crash Sensor: Serial number: 3505ZRB405E70PNC0ORC Rear Side Airbag Crash Sensor (on driver's side): Serial number: 3515ZRB40556JIHQF9VR Passenger side rear thorax airbag crash sensor: Serial number: 3525ZRB40576JIHQP8MU No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 7E0 920 870 A HW: 7E0 920 870 A Component: KOMBI H16 0111 Serial number: 00000000000000 Coding: 160F00 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041 ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod VCID: 27570CF25E611DB120-8072 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 7H0 937 087 B Component: GW-K-CAN TP20 0207 Coding: 042300 Shop #: WSC 02756 790 00000 VCID: 70E527AEA32F1A09B1-8024 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb Part No SW: 7E0 920 870 A HW: 7E0 920 870 A Component: IMMO H16 0111 Serial number: ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 27570CF25E611DB120-8072 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H07 0070 Revision: 3A001001 Serial number: 00000128849235 Coding: 0300000100000000 Shop #: WSC 20117 959 97404 VCID: 3065E7AE63AF5A09F1-8064 No fault code found. End-------------------------(Elapsed Time: 03:01)--------------------------
I'll give the code tags a crack next time. Thanks Hawk.
Code:Like This
