for those wondering how Tig goes on the sand read on
We recently spent a week on Moreton Island (off Brisbane), with the Tig loaded to the hilt, roofbox and a towball mounted backrack on as well (more to come on that in another thread later). So back was down a bit and we lt our tires down to 18PSI for driving on the sand.
We got off the Ferry at high tide and had to drive on the drier sand and use a number of inland tracks. In the end we ended up going all over the island, which by the way is fantastic.
In summary:
- the Tig handled it all extremely well
- an extra 5cm+ clearance would have been handy and more relaxing, we were acting like a grader a more often than I'd like
- Tig romped up Harpers (a longish steep sandy slope up to the lighthouse), wife was a bit freaked but Tig blew it away, probably could have done in 2nd gear
- the extra torque of the APR map was brilliant
, despite high loads and grader driving, 2nd gear and even 3rd were fine, except a few occassions when I got down to almost walking speed on some soft sand, which were the only times I really needed first.
- with the remap (and probably without) dont need a low range, Tig is almost unstoppable in 1st, only time might be an issue is literally crawling across very rough terrian, but I'm not even sure that would be a problem
- Tig did well with lots of creek crossings
, a little hairy, as had to time with waves and keep a bit more speed thru water than I'd like just in case sand proved softer than expected (I got out and tested it a number of times), but I was conscious of keeping to shallow water only as know fording ability of the Tig is very limited
