I am the one that bought a set of LHD electric folding mirrors from Germany. The LHD mirrors have a different mounting angle set and as such will not adjust enough in to allow you to see the LHS of your car when reversing etc. I ended up buying a RHD unit from South Africa when I was on holiday there. The LHD unit for the driver's side is still useable providing you sit back far enough.
All the kits I have seen so far on ebay Germany are sold with the older door modules which are only suitable for the pre facelifted Tiguans. However if you have a 2012+ Tiguan and only want puddle lights, the fitted basic UDS controller with 7 pins includes the +ve pin to support puddle light. You will however need to run a wire from the module to the mirror unit and re code the door modules using VCDS.
BTW the seller on the link above is out of stock but he did leave us a part number 5n0949101c/2c to allow us to search other sites
Original Blinker Aussenspiegel Spiegelblinker Speigelkappe LED VW Tiguan Rechts | eBay
MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
