Sometimes i wish my keyboard was broken...![]()
The diameter of a circle is the measurement from one side to the other.
So if you measure across a wheel (including the tyre) of course, lying on the ground and it is 834mm you may only go to 849 mm
Look here and put the sizes in and you will see the difference and what it does to speedo etc
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Wow, great tool - thnx!
The following tyres are OE factory fitments on a Tiguan:
215/65 R16 98H
235/55 R17 99H or V
235/50 R18 97V
255/40 R19 96V or W
so there shouldn't be any issues in using any of the above tyres.
I've no experience with the above tyres, but here's my 2 cents:
Pirelli classifies the Scorpion Verde as an SUV tyre. It's the newest in terms of design and has an emphasis low wear and low noise (looks similar to the Cinturato P7), with reasonable road-holding. As long as you're not intending to go on track days, I think it's worth the premium over the others. This tyre appears to suit your needs best.
The Hankook and Kumho are high-performance passenger car tyres, with an emphasis on grip and handling. Wear, noise and light off-road duties are not their forte.
The Dunlop SP Sport 01 is an older design and IMO, not worth the savings over the Pirelli, or the premium price over the Hankook or Kumho.
Based on all the information you've provided so far, I would look at purchasing passenger or SUV tyres.
All-terrain or light truck tyres seem harder to justify for your particular needs and intended usage patterns.
If the idea of 18" wheels on your car is too appealing, my suggestion is to try them and see how you go, but hold onto the 16" wheels and tyres.
After a while, if you find the capabilities and characteristics of the 18" wheel and tyre to be really lacking, then just swap them back.
Went to check out the rims today but they were sold! Bugger!! If anyone has 18" Davenports, you know who to PM![]()
Getting back to the thread topic - "Off Road Tyres" - would not 3 ply sidewalls be recommended ?
I know 215/65 R16 Pirelli P6 and Hankook Dynapro's have a 1 ply sidewall - it is on the tyre. Not ideal for "off road".
Any recommendations for legal size R16 Tiguan tyres with 3 ply sidewalls ???
Golf - MY11 Candy White 103 TDI DSG
Sadly SOLD Tiguan - MY11 Candy White 103 TDI DSG
I would focus on the tyre's intended application. For instance, a passenger car tyre with a 3-ply sidewall still probably wouldn't be as useful overall when compared to an all-terrain tyre with a 2-ply sidewall in off-road conditions.
The Pirelli P6 is a passenger car tyre. The Hankook DynaPro HP RA23 is an SUV tyre designed for on-road usage. Irrespective of how many sidewall plies they have, I don't think they wouldn't be as useful off road compared to an A/T tyre.
To get the ball rolling, below is a list of suitable tyres (though far from comprehensive) for your consideration, if off-road performance is the main criteria:
Bridgestone Dueler A/T D697
Continental ContiCross Contact AT
Dunlop Grandtrek AT3
Yokohama Geolandar A/T-S G012
Me too, I'm keen to get a Tiguan and take my family to some of the places I ride my trail bike.
I am thinking of getting another set of 16" steel wheels and putting a set of BF Goodrich All Terrain tyres on them for those special adventures.
Has anyone succesfully fitted 235/70 R16 or 235/85 R16 tyres to the car?
I don't mind if I have to raise the suspension an inch to make it work.
235/55 R17 have a rolling diameter of 690mm
235/70 R16 have a rolling diameter of 735mm
235/85 R16 have a rolling diameter of 805mm
Used this to determine outside diameter Tyre dimensions: 235/85 R16
Thanks to all for the contributions re offroad tyres.
I decided to go with the Bridgestone Dueler A/T 697 215/65 R16C 106/104S. These are labelled LT (Light Truck) tyres.
$209 fitted from BJ's.
From the sidewall info:-
Plies: Tread 2 Polyester + 2 Steel + 1 Nylon, Sidewall 2 Polyester. Made in Thailand.
I have just completed a return trip from Brisbane to Weipa, including the Bloomfield/Daintree track without any problems.
Over 1000 klm of dirt roads with 5% "bad" corrugations, and another 5% of rough dirt road.
On the rough dirt I was overtaken by a quite a few Landcruisers/Prados/Nissans with camping trailers, but I usually went past them at their petrol stops !
No new rattles or noises. Had a wheel alignment check at Charters Towers on the way back - all OK.
Very impressed with our Tiguan. Averaged 6.3 litres/100 klm over 6500 klm. After a good clean, it looks like new again.
Tiguan at Laura, after trip to Weipa.
