Page 12 of 24 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #111
    Re: New firmware for RNS510/Columbus versions 4120 and 5210
    I'll post it to The Mad Monk and ask him to transmit it by telegram.
  2. #112
    OK, I have uploaded the newly modified 4120 firmware image thanks to Zeit20t for hosting.
    WARNING! This is a beta release and has yet to be tested.
    I need someone with access to VCDS to test load this and see if the coding is maintained and report back.
    In summary: this is a modified 4120 fw image that should be non-factory (ie maintain coding, radio presets etc) and has had hard drive partition sizes changed to 90/5/5 for Australia/NZ maps to maximise music space. Also has VIM and secret menu enabled.
    http://m35stagea.info/skoda/4120_FW_90_5_5.ISO
  3. #113
    Jan 2012
    thanks dude!
  4. #114
    Apr 2010
    I could test it but knowing 5120 or whatever it's called is floating around ready to be modified some day I might just wait for that (considering how many attempts it took me to get 4120 working).
    Will get a copy up on the other site too, wonder why it didn't work for you
  5. #115
    Mindarie, Perth (WA)
    Is dropbox suitable for hosting dowloads?
  6. #116
    Jan 2012
    I have an ISO with 5218 in the model number. the file structure is slightly different, has DAB and TSW directories.
  7. #117
    521x doesn't add any new features (that we can use) that I can tell, 4120 has RDS and male voice.
    There will be an upgrade version of 5xxx firmware some time in the next few months but unless you have a DAB tuner board in your RNS its not going to do anything extra.
  8. #118
    Jan 2012
    ahh damn, I was uploading it to the site in case you (or anyone else) wanted it
  9. #119
    I've already got it, have no reason to use it at this stage. The RNS510 units with DAB boards are apparently going to be produced from week 45, this firmware is to support them.
  10. #120
    Apr 2010
    kamold's 4120 90-5-5 mirrored here:
    https://docs.google.com/open?id=0B4f...U9tREkyQVdvb2M
    (don't use this yet since kamold had to fix a problem and I haven't uploaded v2 yet)
