Just tried it on my MY16 golf highline, works. Thanks
Sent from my LG-H815 using Tapatalk
So you would like a Australia Wide MK7 MIB2 POI Collection Incl Known Police Enforcement Zones?
Well here we go, this is further to this I have complied my most used POI's these include:
SAFETY CAMERAS
BP
Caltex Woolworths
7 Eleven
Fixed Speed Cameras
McDonalds
Shell
Red Light Cameras
Mobile Speed Cameras
Also includes Trapster data for Known Police Enforcement Zones in Australia
However these are from September 2013 but still very valid!!
All other categories are updated to the latest version as on poidb.com
This is already converted to be copied over to a SD Card and imported, please note this will wipe all current POI's you have loaded so if you want the raw data in .KML files to compile yourself - PM me & make a donation.
POI_BY_TUZII.zip - Google Drive - Google Drive
Dropbox - POI_BY_TUZII.zip - Dropbox
Use these files at your own risk as I accept no responsibility for any missed cameras etc.
This has been tested on a MY 16 MK7 R, with 6.5" MIB 2 with version 0420 Maps, it should work with all Map versions
Install instructions:
Step 1: Extract the ZIP file to your SD Card - It must be extracted to the ROOT of the SDCard
Step 2: Insert the SDCard into SD Slot 2 (in the glove box of your car)
Step 3: Press the NAV button on your MIB II
Step 4: Press Setup --> Manage Memory --> Update My POI's --> Update --> Select SD Card 2
Enjoy
Make sure you like and join Volkswagen Owners Sydney
https://www.facebook.com/VolkswagenOwnersSydney
https://www.facebook.com/groups/VOSydney
ps. If you would like to make a donation as I saved you from a fine or a few, PM Me.
"Forced induction" sounds like some sort of sexual assault.
i drive a Golf 7R tuned by APR + exoticars
How do I select which POIs show up by default?
Also how do I turn off the tone that goes off each time I go pass one of the poi's.? Thanks
The tone is built into the zip file. Its selected during the creation process. I am not aware of anyway to individually disable it for each poi except during the creation process. This doesn't mean that there isn't one though.
EDIT: Here is a link on how to do it, it includes a link so you can choose your own poi's and make your own files. Its extremely easy. You can add mulitple POI files into the creation process.
MIB II - Custom POI's / Speed Cameras etc
Ok thanks for that, sorry to say but for me having that tone go off all the time which slightly turns down music volume each time is enough to stop me using these poi's, how do I remove them and go back to factory settings. Thanks.
I followed the instructions and successfully created a Personal POI file for the MIB 2.
POIdb.com seems to be updated fairly often, its a fairly straightforward process to create a custom file with the POI groups you are interested in.
The above link has an excellent how to...
My16 Golf Alltrack, DAP
MY18 Golf Comfortline
