after the upgrade to 0.4.1, my mirror drop feature is working very well!
Reposting here from the AutoPolar forum - hopefully this makes some sense:
TURBO PRESSURE parameter (extend info)
Hi to all AutoPolar users,
Due to receiving questions about this parameter, we will provide an explanation to try to clear all doubts.
If you have any other questions, please post all your concerns, and we will complete this FAQ.
How do I need to configure my PolarFIS to read turbo pressure correctly??
To make a proper turbo reading pressure, normally is not necessary to configure anything in your PolarFIS unit.
There is a configuration inside the unit that automatically selects the best option.
However, there's a few models in which this automatic function doesn't work correctly.
This guide will help you to identify if this is the case for you.
These are available options in the pressure configution menu:
- AUTOMATIC : PolarFIS will select the best option for your vehicle automatically. RECOMMENDED !! (by default)
- INFORT X1 : To obtain the turbo pressure from the infortainment bus.
- INFORT X2 : To obtain the turbo pressure from the infortainment bus. The reading is multiplied by 2 (only vehicles in which the bus only shows half pressure).
- DIAGNOSIS : To obtain the turbo pressure from the diagnostics bus, for vehicles that the other options don't work.
What values does the PolarFIS show in my screen ?? I not have idea ...
The value that PolarFIS displays is the result of substracting the barometric pressure from the boost pressure read from the bus.
This is due to the boost pressure sensor indicating the absolute pressure (BOOST+BAROMETRIC)
But, sometimes I see negative values, why does this happen??
Normally with the engine at idle, there must be some vacuum in the intake manifold, so tehe pressure reading will be negative (around -5 to -15 mbar or -0.07 to -0.2 PSI), this is normal.
However, in some models there's no negative readings and with engine at idle the reading is 0 mbar or PSI, we can't do anything about this because the data is read directly from the Diagnostics bus of the engine ecu.
A small negative reading as indicated is normal, however if you have a reading less than -100 mbar or -1.4 PSI it means that boost is not reading correctly.
In that case, you must enter in the Polar FIS configuration menu, and select SCREEN->VISUALIZATION->ADVANCED->BOOST OPTIONS and choose the option INFORT. x2.
This is due to in some cars, pressure read from infortainment is divided by 2.
If the problem persists or you have no reading of boost pressure, enter in the same menu and choose DIAGNOSTICS option.
Is there a trick in roving the wiper arms in mk6 golf r? I have removed the 2 nuts but the control arms will not budge. Been pulling and tugging but still will not come loose.
Regards
Orr
They are spring loaded when you have the wipers down one the windscreen. Suggest trying to "park" your wipers and then lift your wiper arms so that they are in pointing up.
Not sure if this will solve your problem but I found if you take the tension off the spring pushing the wiper against the windscreen that this made things easier.
turn on ignition. turn off ignition. press the wiper stalk down once within 30 seconds of taking the key out.
that's the service position.
I've tried that but the arms will still not
come off. Also have tried removing the wipers from the arms. Sorry to sound like a noob.
I have heard of others having challenges - seems that some are harder to get off than others.
You could try asking in the tuning section as some of the tuners often need to pull of the wipers/rain tray to get to the ECU on some cars.
They may have some suggestions that could help.
All else fails go via the dash.
I've sometimes had to use a bearing puller when the arms are frozen on (usual cause is corrosion.)
Carefully applied heat might also help.
