Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Who stocks 506.01
    Gosford Central Coast NSW
    Not that it would negate the costs in any way, but I would have thought that you could safely use 507.00 approved oil as long as you were willing to change it more often.... but this is only really a discussion opener, rather than me saying that is really the case.
    I was always under the impression the xxx.01 spec was for the variable service interval option - where the oils have the extra unobtanium as brad so elegantly puts it, in order to prolong the high pressure lubricity of the oil.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Adelaide hills, SA
    I'm stuck with the 506.01 oil and as long as I can get it I wouldn't dare to try 507.00 in it. The AXE engine in my T5 was made in 2004 and as such has to be run on 506.01 only, however the owner's manual was also referring to 505.01.
    Yes, the 506.01 oil costs a bit more, but it's still cheaper than the engine repairs
    Dec 2005
    Rockhampton Qld AU
    So, I would rather use 507 as well because aussies don't do long life. But from my research, the 506.01 IS a different oil to the 507 and I will use it as long as I can get it.
    But, a supplier I found says that Fuchs won't be importing the 506.01 anymore. I bought his remaining stock. I hope my car last for 4 more years or so.
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Adelaide hills, SA
    Quote Originally Posted by njg02 View Post
    There is also LiquiMoly with 506.01 specs.
    Who stocks 506.01-20120724_141725-jpg
