Side one, the one on the left:
Once these bolts are removed the pump can be swung away and u can see the housing. Its held by two 10mm bolts and u can remove them.
Out of the way:
Housing:
I find that its easier to wait until after the housing is loose to drain all the coolant. The bottom radiator hose is an ass to remove and the worst is trying to reattach the connection to the bottom outlet. The clips are a bugger to remove too since they are always in the worst position. I bought the remove hose clamp pliers which makes it much easier, if ur in the area u can borrow it off me if need be!!!
Thermostat out:
If the thermostat is hard to get out, just use a screwdriver and pry it out since u wont be needing it . To put everything back in is the reverse. DO NOT FORGET TO PUT A NEW O-RING IN!
Before u put the thermo back in i'd flush the system with some distilled water now.
