In my opinion one of the best bang for your bucks is the APR Engine Mount Insert. It's inserted into the existing engine mount, which greatly reduces driveline shock and drivetrain slack, resulting in improved power transfer. I managed to buy one for about $90.
Installation is simple - You just jack the car up, remove the engine cover that covers the engine mount, remove the bolt that holds the current mount and then with lots of lubrication push the insert into the existing mount and replace the bolt.
I was a bit apprehensive about it at first since I heard it increases drivetrain vibration, especially in a diesel.
I can report that there's definitely more vibration in the car but only when she's cold in the morning - start up really shakes the car into life ( it was very concerning at first ) and then the car keys go into this harmonic vibration from the vibrations. Take off when cold is very touchy- no longer very absorbed or fluid like - more like a racing clutch has been installed. This is all goes away after the engine warms up within about 5 minutes though and then its very similar to before. If the car goes into DPF regen mode or the compressor kicks in for aircon you can feel the change in revs more ( kind of bangs ) but apart from that it not too bad. I can happily report that after a few weeks it settles down a lot and is much less noticeable ( maybe its just me getting used to it though ) .
The traction is the biggest surprise now - not only is the axle tramp completely gone but it seems to grip a lot better. Whereas before it would spin like crazy and axle tramp all the way through first gear and the again spin in 2nd and sometimes chirp in 3rd I now spin off the line smooth and slamming it into 2nd only brings a small chirp. Too bad I never took any proper 0-100 times before and after because I swear she'd be so much quicker just because its easier to launch. Fantastic cheap modification that everyone should buy!!! Highly recommended. Hell its always removable so if you don't like it you can take it out.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
