It'll either clear the light, or it wont.
If it does, it'll get you out of going to the dealer.
If it doesn't, it'll probably need a forced regeneration.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Just fitted new sensor, those hoses were a p@#$%, did the ignition on off 3 times, cleared the fault light with a launch scanner, started
the car a couple of times, light has'nt come back on yet, see what happens when I take for a drive.
Thanks everybody for all your help, keep you posted on the outcome.
bmwrider
united grey gt sport 6 speed manual
Hello everyone,
I own a VW Passat station wagon 4WD ( 4 wheel drive) of 05 /2006 ( should be a 3C5 ) , displacement 1968 TDI , Power 103 k , diesel , bmp, manual transmission, FAP/DPF .
After starting the amber light of the exhaust gas, the mechanic using his computer for diagnosis , told me that the computer has detected a problem with the oxygen sensor and so it has to be be replaced.
Initially, the VAG marked the error " oxygen lambdasensor " , but now the sensor has been replaced but the same indicator light persist with a new error obtained by reconnecting the computer-VAG: exhaust gas pressure sensor G450-Signal too High .
Soon I will also change this sensor and then hope that this " Christmas tree" stop light and everything resumes to normal operation !
In addition, the consumption of late have changed for the worse !
Thanks in advance to anyone who can give me more information and help on this matter ..
bye,
sgtpepper
