I was under the impression with AGM batteries/stop - start systems you should only use a genuine battery and you're right about the coding, on ODIS it gives you a pre-selected list of batterie sizes, e.g: din rating, CCA rating, amps etc. I was also under the impression you should not go more than a genuine battery as it will effect stop-start among many other things?
