For the record, the clear film is pretty effective for scratch resistance. Cheap too and easily replaced when required. Only caveat is that it runs up to the edge but not right over it.
A metal one will still scratch up properly.
I'm looking for metal load sill protection (AKA scuff plate, bumper protection, etc) for MY13 Passat Wagon. The only option in the accessories propaganda is the clear film, which is not what I want.
Asked my local dealer if a stainless steel option exists, which they say yes, $185. Fine, the next best option I've found is on the UK which would cost about the same with shipping from UNQShop .
Collect it today, it's ABS plastic with metal like finish. Spewing, no way this is worth $185. Also what the reason I want protection is to reduce scratching, this thing will scratch just the same as the bumper. For reference the VW part number for the faux metal strip is 3AF 061 195
Does anyone know of any local sources for real s/steel protectors?
08 Golf GT Sport TDI - Blue Graphite, Manual
13 Passat 118 TSI - White
I have 3M film from the rubber seal right down to the chrome strip Right to the outer edge of the little door for the towhook. Put it on my self Cost about $40 Just be careful not to drag stuff across it Mine is 2 years old and have done all the doorsills and the stainless strips on the sills as well
You could ring Ozishield in Melbourne and they could do it for you Thats where I bought mine and cut it to fit.
They do however sell cut shapes for our Passats
OziShield Paint Protection Film Home Page
I wonder if the stainless steel sill protector from the B6 would fit?
Volkswagen Accessories - Boot sill guard – chrome effect
p/n: 3C9 061 195 for the wagon.
Mine is still holding up. First one only lasted a year before it got munged up (along with my rear bar) when I got rear-ended. Replacement still looks brand new almost 2 years later. The first one wasn't quite fitted correctly. It attaches with double-sided tape, and mine was always lifting. The replacement fits perfectly.
No obvious scratching on mine yet, and I don't particularly baby it. If I'm loading something heavy into the cargo compartment, I'll often lean it on the sill guard before lifting it up and over the sill.
I reckon metal>film. Sure, the film will provide a BIT of scratch protection, but it will only provide minimal impact protection. The genuine VW stainless steel sill protector is at least 1.5mm thick (probably closer to 2mm), so it's going to provide some pretty serious protection.
Has anyone had any experience with this: Carbon Style Rear Bumper Protector VW Passat 365 Estate | eBay?
Looks quite stylish and inexpensive compared to the other options. Not sure how durable it would be though.
The reason I wasn't considering the clear film is that I expected dirt build up around the edges of the film, essentially highlighting the film on the white paint.
I reckon a metal plate will hold up fine against dog claws.
Well if you use the cleaner polish on it every couple of months there wont be any
Both my cars have it on them and you literally have to look for the edges even after nearly 2 years. Just be careful when you wash it not to rub across the wrong way.
Toyota Corollas have a piece in front of rear wheel from the factory and they dont show dirt.
For what its worth the taildoor shape is exactly the same on the previous model as is the bumper shape at the top.
I was going to get the chrome strip that goes across the bottom of the door that the B6's had but not the B7
So I made a template and then put it on a B6 and its identical so logically a B6 unit will fit
The Problem with rear bumpers is not only the fact that stuff gets put onto the top but gets banged into the face of it when people dont lift stuff high enough.
Spent half my life when Taxi driving getting bumpers touched up with tired passengers who would insist on "helping" to put stuff in the boot and scratching the bumper.
Have you looked on eBay or AliExpress?
I couldn't see any wagon units but stainless steel for the sedan starts at $30 shipped.
Well, I just ordered one of these: Rear bumper protector (Perfect Shape) VW Passat B7 , only for Estate. Thanks ted for the original link. I'll let you know how it turns out.
