Results 21 to 30 of 33
Thread: Shifter bracket mounts, fit 9N3 Polo and various other cable change boxes.
  1. #21
    Oct 2010
    Melbourne, VIC
    I just fitted the ones that I got from Gavin when he came down for work and met up with a few of us.
    Aside from the difficulties removing the typically overengineered airbox, it was really easy to replace the bushes and the end result is a noticably crisper gearshift (on top of the improvements from previously fitted the Forge short shifter and the 42DD bushes).
    Thanks Gavin and let me know when you're back down again
    Resident grumpy old fart
  2. #22
    Replacement bushings for the bracket that holds the shift linkage to the top of the transmission bell-housing. Eliminate the worn out OEM rubber bushings and tighten the feel.
    I was surprised when I fitted mine, how much of an improvement there was.
    If you fitted these with the 42DD cable bushes from Greg Roles, you would notice even more improved shifting.
    $42 shipped over night.
    Easy to fit once you can get to the bracket. You will have to remove the airbox for access on most cars.
    Bumping, got 3 sets available.
  3. #23
    Down to the last set folks. Any takers?
  4. #24
    Nov 2012
    WA
    I'll take one
    08 9n3 Polo GTI
    Mods: heaps
  5. #25
    Quote Originally Posted by rgvlee View Post
    I'll take one
    I'll pm bank details now, send me your address back, I'll bag them up and send Monday.
  6. #26
  7. #27
    May 2014
    Newcastle, Australia
    10 more sets on the way. Should be in by the end of next week.
    Did these end up fitting a mk3 vr6 shifter?
  8. #28
    Quote Originally Posted by cliftronix View Post
    They will.
  9. #29
  10. #30
    February, got several sets on the shelf. Fit lots of cable change gearboxes.
