I've been driving my 162TSI Sportline full-time for the last month. Here's my thoughts on what works/doesn't work for me and what I find annoying.
Firstly I have to say I quite like it even in stock form. My wife didn't want to hand over the keys and I understand why. It's a nice place to sit. The panoramic sunroof is great on sunny spring days. It's pleasant to drive on the highway and after a long journey I'm not totally exhausted. In comparison to the Scirocco it's a much more relaxing car to drive on long drives.
The 162TSI has got decent pulling power on the highway for overtaking. Off the line "D" is a bit doughy. You really need to bump it into "S" if you need to get going / want the car to respond with a level of urgency. But then "S" mode hangs onto the gears a bit long for stop/start city traffic and this gets a bit annoying. So I mainly leave it in "S" and hit the cruise button as soon as I'm up to speed which helps with shifting into higher gear. So it's a bit of a work-around but mostly works OK.
A couple of things that I found a little annoying. The fact that the Haldex engages at low speeds and locks up the rear wheels causing the rear tyres to scrub is a mild concern (more details
here). Stop/start is just plain annoying as it often cuts out just when you least want it to like stopping at a Stop sign and then have to restart almost straight away. The nag screen on the head unit that comes on every time you drive and won't go away until you clear it.
I'd have to say the seats in the Sportsline are not quite as supportive as the Sports cloth seats in the old 155TSI Gen 1 Tig. I find I still slide around in the Sportline seats as the side bolsters are too low and the seat too flat. But that's just mildly annoying when driving a bit harder. For general day to day use they're fine.
Adaptive Cruise works well, however it's default setting is 3 bars and I find in city traffic that's just too far. So I end up cycling through every time I start the car to set it to 1 or 2 bars which is a bit annoying. Also it does tend to cut in/hang onto cars longer than I'd like but I think that's pretty standard for adaptive cruise control systems (my previous car did this also but perhaps not quite as much).
Adaptive dampers are good - usually leave it in the middle setting as comfort is a bit too soft around corners and sport does let more of the bumps/uneven road surface through.
