For those of you with towbars installed, do you have the following in your Central Infotainment Display?
If you go to Menu --> Vehicle --> Settings --> Drivers Assistance: Do you have trailer recognition sub-menu?
(YouTube)
It wasn't there originally for me but I coded it in the Trailer Module:
There are a few other trailer related settings I was going to code but didn't want to do too much before actually trying out something on the towbar. I just want to know if Trailer Assist where you use the mirror adjuster can be used to place the trailer whilst reversing.
Will eventually get more time to find out the answer if someone else hasn't already beaten me to it.
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Yep I have it. I can't wait to try it though. See how good it is
I have this year June build with RLine
Vw fitted not exactly sure of brand. I'll double check
Hi Jap
Please could you post your codings & adaptation channels so I can compare. I followed these instructions on my MY17 Tiguan R-Line:
Activate Trailer Assist - VCDSSchweiz
I had the genuine trailer electrics installed by dealer, so car knows when trailer plugged in, but Trailer Assist never worked. After altering the above coding & adaptations, I now get a message that Trailer Assist is available and to press the Park Assist button when the car is in reverse - once I do that, a picture flashes up showing how to control via the side mirror selector/adjuster, but then an error message comes up to say take control of the steering wheel as Trailer Assist is not available due to the reversing camera being obscured.
I have no idea why this error occurs, as the camera is clean, I have removed the jockey wheel & re-routed the trailer plug out of view in-case it is getting confused.
I did have a problem with the final adaptation change, as Klemme 15 does not appear in the drop down list??
Any assistance would be greatly appreciated.
Backup
Control unit: 69 Trailer Function
System description: Anhaenger
Software number: 5Q0907383H
Software version: 0204
Hardware number: 5Q0907383C
Hardware version: H21
Serial number: 0428187970
ODX name: EV_TrailFunctGener2Hella
ODX version: 001008
Backup name: trail
Long coding:
0100000202000000
Adaptations:
Production mode:
Activate start-up mode:
not active
Control module switch-off, counter:
Control module:
0 min
Data bus:
0 min
Control module switch-off, switch-off time:
Control module:
30 min
Data bus:
15 min
