Page 56 of 118 FirstFirst ... 646545556575866106 ... LastLast
Results 551 to 560 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #551
    Nov 2013
    AUS
    Anyone done the overtake on the left fix with VCDS. Had this happen a couple of times on a multi-lane freeway / road when the car slows to the speed of the vehicle to the right and it's a bit painful.
    I have done it, will need to see if I have it written down somewhere.
    Edit:
    Looks like I hadn't written it down when I made the change and just did it when I stumbled upon it.
    Just did a quick google for Golf Mk7 version, try this:
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  2. #552
    Quote Originally Posted by Moveingfaster View Post
    Just tap your foot on the gas pedal and it will resume your set speed
    Yeah I know that it’s just the cars behind you don’t expect you to slow down.
    Going to code it out because it’s possible to cause an accident the way it’s working. Rather not get rear ended.
    Quote Originally Posted by veew View Post
    Edit:
    VCDS (VAG-COM) codes and programmable options for Golf Mk7 - Page 145
    Thanks I’ll give it a shot when I’m home and report back!
    Success!!!
    It wasn’t quite as easy as I had to find which module the setting was in and then required a security access code to change the setting:
    Module: 13. Auto Dist Reg
    Security Access Code: 20103
    Long Coding Byte 2: Overtaking Right Prevention Active (unselect)
    Security:
    Long coding Byte 2 (default settings):
    Long Coding Byte 2 (unselect overtake prevention)
    Module coding:
    Do it!:
    Nov 2013
    AUS
    Success!!!
    Glad you found it, will add it to the library in the first post.
    Just to clarify in more detail for others looking at this setting:
    This tweak is helpful on the freeway when you are not in the right lane and approach a slower car driving in the right lane.
    Usually the car slows to the other cars speed (annoying if the car in the right lane travelling at 100km/hr in a 110km/hr zone) and does not proceed past them.
    Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane without additional intervention.
    Current:
  6. #556
    Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane.
    Doesn’t even have to be on the freeway. If you’re on a multi-lane road and the cars in the right lane slow then you will also slow to not overtake on the left.
    I find this annoying and dangerous. People behind you do not expect you to slow in this situation as it isn’t “normal” behaviour. The slowing isn’t gradual either (like taking foot off and coasting) it’s a more rapid deceleration to stop you from going past the vehicle in the right lane.
    At least by disabling the function I have a choice.
    Quote Originally Posted by PapaLeguas View Post
    Hi Everyone, i am from Brazil and in my country the Tiguan Rline 2018 isnt enable Lane Assist. The car have camera module A5 on VCDS. Someone have the step by step to enable this function? Best regards my friends.
    Enviado de meu SM-G950F usando o Tapatalk
    Hello Someone! I would like do coding by VCDS Lane Assist. Someone have the step by step. I did on Passat B8, but in Tiguan Allspace didnt work. Best regards.
  8. #558
    Post a full autoscan and admap of A5
  9. #559
    Its so big allscan.
    Below just the module A5.
    Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
    Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
    Component: MQB_B_MFK H08 1272
    Serial number: 04061841K10027
    Coding: 000307060102010100221344C150490000000E300140
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_MFKBoschMQBB 001001
    ROD: EV_MFKBoschMQBB_001_VW36.rod
    VCID: 885CF3113370E30A1E-80DC
    No fault code found.
  10. #560
    Its so big allscan.
    Any news my friend. Please help me. Best regards.
