Page 26 of 118 FirstFirst ... 1624252627283676 ... LastLast
Results 251 to 260 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #251
    May 2014
    Russia
    Quote Originally Posted by jbaldy View Post
    What module is this in?
    Sent from my iPhone using Tapatalk Pro
    Central electronic 09
  2. #252
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by NZ_GolfR View Post
    Yes but that is a Tiguan in the photos with the colour change.
    Did you also get the menu on discover to select colours?
  3. #253
    Nov 2013
    AUS
    So this just changes the colour of the central display? Does it affect the colour of the ambient lighting in the doors etc?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #254
    May 2014
    Russia
    Quote Originally Posted by veew View Post
    Tiguan does not have RGB diode. Only white color
  5. #255
    Aug 2016
    Auckland, NZ
    So slight twist of events. Went to try and code in the gold colour so I could have the Infotainment unit match the AID and when I set the AID Display Depiction to Version 3 it was no longer gold. It seems with setting the custom colour options it now inherits whatever you have it set to:
    Here are a few other examples of the matching colours:
    Not the best photos, sorry, as it was dark.
    One thing to note I have discovered with the custom colours, all 10 have to best set. If any of them have the RGB value set to 0, 0, 0 then it doesn't work.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  6. #256
    Aug 2017
    Netherlands
    Looks cool! So what exactly is the coding for all this? And changing it on the Pro also changes the AID now?
  7. #257
    Aug 2017
    Uk
    I think it's done in central electronics so changes both at same time
    wheres the settings listed in the mib to get the colour menu up?
  8. #258
    Aug 2016
    Auckland, NZ
    Here are the exact details for the changes using OBDeleven:
    Control unit: 09 Central Electrics - Adaptions - Int. light, 2nd generation - Instrumententafelbeleuchtung mehrfarbig - Set to Active
    Control unit: 09 Central Electrics - Adaptions - Interior light, light configuration - Ambient_Farbliste_HMI - Set to Active
    Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set your RGB Values for all 10 Colour options (Rotwert = Red, Gruenwert - Green, Blauwert = Blue)
    Once you have applied the codings reset the Infotainment unit (hold power button down until system reboots) then go into Car - Settings - Background Lighting and you can switch from Brightness Setting to Colour Setting. Change the colour here changes it in the Discover Head Unit as well as the AID.
  9. #259
    Nov 2013
    AUS
    Man the car is getting better and better! Bit annoying VW releases their cars "dumb"...
    Btw I know others have done so, but thanks to all that have contributed to this thread! I will get around to updating the OP again soon.
    Current:
  10. #260
    Jul 2017
    Auckland, NZ
    Legend! It was bugging me that the AID and the MIB were not the same colour.
