3rd Brake Light - Various VCDS tweaks
I've always found the 3rd brake light to be a much undervalued facility on a car. Truth is that on a mk7, it can be used to do all sorts of additional functions (other than just being a brake light). On my highline, the third brake light was factory fitted with an LED.
Here's some options for how the role of the 3rd brake light can be expanded. I discovered these instructions as part of material that I received from a forum colleague (Many thanks - Morde), who resides in Germany and therefore has access to a richer information base than us English folk (and he understand the German language- which is a great attribute to have when trying to decipher VW's cryptic nomenclature)!
Note: for the three tweaks shown below, the structure of the changes across the Leuchte-set channels (and the non-Leuchte set channels) are arranged so that each individual tweak is independent of the other options. Pick-and-choose whichever tweak that you like (or choose none!),
I implemented all three options on my car this morning and I can vouch that they all work
3rd/High-Mounted Brake Light Tweaks - Instructions
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Standard setting column
- For the wanted options, change the adaptation channels depicted in the table below to the values in the appropriate column (tip: use the "Search" box to locate the channels)
